Page 4 of 4 1 2 3 4
Re: holley billet metering block and emulsion jet question [Re: dartman366] #2468338
03/18/18 10:29 PM
03/18/18 10:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By dartman366
Well,, it's on the car and running,,,and quite well I might add, once I got the float level set which was a little high and started to work with the curb idle screw's it came around quite nicely and sounds a lot crisper, idle tip in is smooth and there is no more blubbering like the other one(which I think I found the problem there) just smooth as silk up to the point the boosters took over, the other one sounded like it was loaded up a little and then would clean up so that is a big plus,, got it up to running temp for a while then shut it off,, let it sit for about 10 minutes and reached in and hit the start button and it was running and never touched the pedal,,,now for the tracks to open and start to dial this thing in. up and also a big thank you to Dom for bailing me out with good straight forward no BS answers and tech advise. up up
This is what I like to hear and now the tuning will begin but kudos to you for tackling what some consider too hard or impossible to do and I get it.......... beer
Re: holley billet metering block and emulsion jet question [Re: Thumperdart] #2468391
03/18/18 11:54 PM
03/18/18 11:54 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
Glad to hear Dom got you pointed in the right direction!! up Heres my new Dom built carb waiting on an install and test. I'm still not sure if I need to put it in the China cabinet or on the car!! grin
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: holley billet metering block and emulsion jet question [Re: G-Money1320] #2468969
03/20/18 09:36 AM
03/20/18 09:36 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
What size venturi & throttle? Looks like a Holley aluminum replacement main body wrapped in TC's preferred hardware.
Re: holley billet metering block and emulsion jet question [Re: BradH] #2469126
03/20/18 02:15 PM
03/20/18 02:15 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I THINK this one is the 1.610 bore and 1 3/4 blades but shipped so many lately I forgot........... punkrocka
Re: holley billet metering block and emulsion jet question [Re: Thumperdart] #2469419
03/20/18 10:48 PM
03/20/18 10:48 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
Well it took me two and a half solid days to do it and several times I had to walk away from it for a while,,, but I guess persistance paid off, or maybe it's just stubborness.LOL whistling
Re: holley billet metering block and emulsion jet question [Re: dartman366] #2469795
03/21/18 04:41 PM
03/21/18 04:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I do that DAILY..............LOL
Re: holley billet metering block and emulsion jet question [Re: Thumperdart] #2470087
03/21/18 11:05 PM
03/21/18 11:05 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
Yes you are correct Brad. I just have a small 416 though. smile A lot of phone time and I believe Dom has me where I need to be!
Re: holley billet metering block and emulsion jet question [Re: Mattax] #2477740
04/05/18 06:07 AM
04/05/18 06:07 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Finally had the plate off, and the jets are above the fuel. Can I just drill and tap them into the lower hole? Or should I get a different metering block from someone who knows how to set one up?
Re: holley billet metering block and emulsion jet question [Re: dartman366] #2477751
04/05/18 08:47 AM
04/05/18 08:47 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
You can drill and tap them. By hand, not with a power drill. Get in touch with Thumper for details.
[image][/image]
Re: holley billet metering block and emulsion jet question [Re: jbc426] #2477796
04/05/18 11:16 AM
04/05/18 11:16 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Use the ones you have.
See "Relocating the Holley Idle Jet"
RFS - Holley - Tips & Info Stickies
Page 4 of 4 1 2 3 4
