Re: A Engine Offset Cam Keys? [Re: 340Cuda] #2466443
03/14/18 04:03 PM
03/14/18 04:03 PM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
Originally Posted By 340Cuda
Originally Posted By gtsdude
I used this one, just remember its the camshaft you are moving, not the crank like this one is made for. If you want 4 degrees advance, get a 2 degree key.
I have a belt drive now and don't have to deal with this but cam timing is based on 720 degrees. So a 4 degree key will affect the Intake Lobe Center 4 degrees. Correct?
That is correct as long as it is a 4 degree cam key not a a 4 degree crank key you are using as a cam key.
Re: A Engine Offset Cam Keys? [Re: gtsdude] #2466477
03/14/18 05:05 PM
03/14/18 05:05 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I hope you degree this cam in because who knows where it’s installed at. I’ve found them up to 22 degrees off
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
