Glasstek 68 Barracuda Hemi Scoop and Hood
#2463102
03/08/18 02:33 PM
03/08/18 02:33 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Is anyone running one of these? I am down to AAR and Glasstek for a hood for my car and I would like some measurements off of a production one if anyone has one. I think AAR will only bolt the hemi scoop on where Glasstek sells the hood with it molded in, so Glasstek is the way I am leaning. Thanks for any info.
68 Barracuda Formula S 340
Re: Glasstek 68 Barracuda Hemi Scoop and Hood
[Re: Bad340fish]
#2463166
03/08/18 04:51 PM
03/08/18 04:51 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
Is anyone running one of these? I am down to AAR and Glasstek for a hood for my car and I would like some measurements off of a production one if anyone has one. I think AAR will only bolt the hemi scoop on where Glasstek sells the hood with it molded in, so Glasstek is the way I am leaning. Thanks for any info. I have an AAR fiberglass bolt on Hood. It also has the tall superstock scoop. What measurement do you need?
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: Bad340fish]
#2463311
03/08/18 08:38 PM
03/08/18 08:38 PM
Bad340fish
Tulsa OK
How far from the back of the hood does the scoop start?
I have a tunnel ram that is pretty tall with the air cleaners on it. I do not think overall hieght is a problem I am a little concerned with placement of the back of the scoop though.
I really want a Hemi Scoop but a cowl might be my next best option.
[Re: Bad340fish]
#2463316
03/08/18 08:50 PM
03/08/18 08:50 PM
Bad340fish
Tulsa OK
Wow, I knew it might be worth something but that is alot.
Choosing a hood is stressful haha, especially when I like the look of the stock hood so much.
[Re: Bad340fish]
#2464193
03/10/18 09:48 AM
03/10/18 09:48 AM
Posts: 162 Chicago-area Illinois
4mopower
I have a bolt on Glasstex hood with a Hemi scoop. The scoop is slightly larger then the carbon fiber hood from Cenergy that i had.
[Re: Bad340fish]
#2515761
07/01/18 10:10 AM
07/01/18 10:10 AM
Bad340fish
Tulsa OK
Update on this, I went back and forth for weeks. With no hood on the car and poor details from the hood makers I couldn't bring myself to order a hood with a scoop on it. So I ordered a glasstek pin on flat hood. I took the throttle bodies off of the tunnel ram and set the hood on the car. Fits perfect, now I just need to get some pins and cut a hole.
Nobody could provide me with measurements of the scoop placement that made me feel confident enough to order a hood with a scoop, the rear throttle body is pretty far back and I couldn't risk it not fitting. Now I will either bolt a hemi scoop on from glasstek, or a cowl, or just leave the throttle bodies peaking out the hood.
Notes for those shopping, glasstek had great service, met the timeline they said, and had a quality product. However they want $320 to add one of THIER scoops to THIER hood in house, that seemed ridiculous to me and is one of the reasons I stayed with a flat hood. I wasn't cool with paying them another $200ish for the cowl I wanted then another $320 to put it on.
[Re: Bad340fish]
#2515790
07/01/18 11:57 AM
07/01/18 11:57 AM
Posts: 8,285 fredericksburg,va
cudaman1969
fredericksburg,va
Notes for those shopping, glasstek had great service, met the timeline they said, and had a quality product. However they want $320 to add one of THIER scoops to THIER hood in house, that seemed ridiculous to me and is one of the reasons I stayed with a flat hood. I wasn't cool with paying them another $200ish for the cowl I wanted then another $320 to put it on. $320 is only 5 hours just for labor, maybe 4 hours for some. Plus materials, $, to attach. I don't think I could do it in 5 hours with all the tools, parts and resin on hand. I did a lot of fiberglass work on my last car and it's a slow, dirty job. I think the scoop goes to the back edge of the hood.
[Re: Bad340fish]
#2515808
07/01/18 12:30 PM
07/01/18 12:30 PM
Bad340fish
Tulsa OK
It may not be out of line, I don't do that kind of work. It just seemed high, they also raised the price $40 while I was shopping hoods maybe that made me bitter lol.
[Re: Bad340fish]
#2518410
07/06/18 01:59 PM
07/06/18 01:59 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
I don't have a glasstek hood on my car but I will say their fit and quality are great! I have their doors and trunk lid. Both required zero filler and little trimming to look great.
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: Bad340fish]
#2544963
09/03/18 10:02 AM
09/03/18 10:02 AM
Bad340fish
Tulsa OK
The GlassTek flat hood turned out good. I will likely add a cowl or Hemi Scoop to it. It couldn't have fit any better really.
[Re: Bad340fish]
#2545019
09/03/18 12:01 PM
09/03/18 12:01 PM
Posts: 4,779 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Thinking out loud here and not telling anyone what or how they should do something. I bought a brand new flat hood from AAR back in 1999 with the intention to cut a hole in it for a tunnel ram. I spoke to AAR before any cutting and he told me since I was cutting thru structure to fiberglass in new structure before I cut. So I cleaned the underside of the hood where new matt would lay in. Cut some 1/2" thick 4" wide strips of celotex foam insulation board. (Hood upside down on lawn) After positioning the foam planks on the underside I glassed them in thus tieing them into the existing structure. Next day I cut my hole and the hood remained just as rigid as out of the big box.
Keep old mopars alive.
[Re: Bad340fish]
#2545057
09/03/18 12:59 PM
09/03/18 12:59 PM
Posts: 2,808 Wisconsin
wkroncke17
Wisconsin
Choosing a hood is stressful haha, especially when I like the look of the stock hood so much. ^^Yes!! Kinda like choosing my auto shifter!^^ 😂😂 I have Glasstek 6 pack hood for my Demon, and the quality is second to none.
