Re: Weird place for a oil leak, Built a Scat 408 engine for a bu
[Re: 727builder]
#2462635
03/07/18 04:20 PM
03/07/18 04:20 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
Yikes, they drilled that one a little deep it looks like.
The right thing to do is replace the crank of course, but if it were mine I would be trying to put a freeze plug or something in there if it is an automatic car and doesn't need the pilot hole.
68 Barracuda Formula S 340
[Re: 727builder]
#2462697
03/07/18 05:55 PM
03/07/18 05:55 PM
Posts: 4,457 Washington
madscientist
Washington
That's junk. I can't tell if it's too deep or the crank has porosity in it.
I'd be replacing that in a hurry. Unacceptable.
On top of all that, the finish machine work looks like it was done by a drunken retarded ham fisted polar bear using dull tools.
Sucks bad but I wouldn't fix it. And if it's a cast crank I'd upgrade to a forged one.
[Re: 727builder]
#2463841
03/09/18 04:44 PM
03/09/18 04:44 PM
Posts: 3,281 West Coast, USA
jbc426
West Coast, USA
I believe Chevy LS motors have a freeze plug style plug in the back pilot hole from the factory. I saw several write-ups about fixing the oil leaks there, while searching for a mystery oil leak on an RB.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
