Page 2 of 4 < 1 2 3 4 >
#2457869 - 02/26/18 11:21 AM Re: Any cutting for TKO600 or T56 install into a 68-70 B Body? [Re: BigHemiVegas]
DaytonaTurbo Offline
Loc: Manitoba, Canada
Sounds like the passon OD gear set would go a good option and be the closest to fit in your budget and be totally stock-fitting. The .8 OD ratio is a bit of a bummer though.
#2457894 - 02/26/18 12:05 PM Re: Any cutting for TKO600 or T56 install into a 68-70 B Body? [Re: DaytonaTurbo]
DAYCLONA Offline
Loc: Mass
with a .80 OD, it's not even worth the effort or expense for so little a gain IMHO, besides the fact the OP never alluded to any indication if his car was already 833 equipped?
#2457929 - 02/26/18 01:24 PM Re: Any cutting for TKO600 or T56 install into a 68-70 B Body? [Re: BigHemiVegas]
RTSE4ME Offline
Loc: MD
Originally Posted By BigHemiVegas
Do you have any pics or video of what you had to cut in order to make that T56 fit in your Charger?
Here is a video of a T56 magnum in a Charger
https://www.youtube.com/watch?v=7Zdov8liz7A
Personally I would either get the Passon 4speed OD or a close ratio T56 magnum.
The TKO trans is not worth cutting up your car. It would be my last choice.
Depending how you are geared now a .80 OD might be fine.
#2457996 - 02/26/18 03:44 PM Re: Any cutting for TKO600 or T56 install into a 68-70 B Body? [Re: DAYCLONA]
moparpoolman Offline
Loc: NE
I am assuming he does seeing his post on rebuilding a 833
http://board.moparts.org/ubbthreads/ubbt...tml#Post2455719
#2458449 - 02/27/18 01:08 PM Re: Any cutting for TKO600 or T56 install into a 68-70 B Body? [Re: DAYCLONA]
BigHemiVegas Offline
Loc: Where else?
Yeah the car is a 1968 Charger factory 4speed 383 car so I really didnt want to alter the shifter hump in it.
Basically it wouldnt bother me to alter the trans crossmember but I didnt want to alter the cars sheetmetal on the trans tunnel or the shifter hump itself.
The Passon .80 ratio OD gearset is really not even worth the trouble as it wouldnt drop the RPM by much at all.
Edited by BigHemiVegas (02/27/18 01:09 PM)
#2458511 - 02/27/18 03:25 PM Re: Any cutting for TKO600 or T56 install into a 68-70 B Body? [Re: BigHemiVegas]
DAYCLONA Offline
Loc: Mass
Your choices are limited then, stand in line for the Passon 5 spd, but your limited to a .70 OD
Or just cut the car and be done with it and go either TKO or T56, IMHO the T56 is the way to go...
#2458667 - 02/27/18 10:01 PM Re: Any cutting for TKO600 or T56 install into a 68-70 B Body? [Re: BigHemiVegas]
67autocross Offline
Loc: Manitoba Canada
T56 all the way even if you have to cut the floor, if the Passon blows you probably won’t be even able to get parts for it.
A new iron curtain drawn across the 49th parallel
#2458668 - 02/27/18 10:03 PM Re: Any cutting for TKO600 or T56 install into a 68-70 B Body? [Re: BigHemiVegas]
Silver70 Offline
Loc: Rust Belt, SW PA
I'm another who says t56 is the way to go... cut it and once you drive it, you'll have no regrets.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
99 Trans Am, 66 GTO, 06 Magnum RT AWD
#2458670 - 02/27/18 10:06 PM Re: Any cutting for TKO600 or T56 install into a 68-70 B Body? [Re: 67autocross]
DAYCLONA Offline
Loc: Mass
I'm sure parts would be available...might take a few years to receive them though?...
#2458679 - 02/27/18 10:30 PM Re: Any cutting for TKO600 or T56 install into a 68-70 B Body? [Re: BigHemiVegas]
67autocross Offline
Parts might be available, but say in a few years the transmissions start failing ,the place goes out of business, or something happens to the owner.....you might wish you cut the floor.
#2458783 - 02/28/18 09:21 AM Re: Any cutting for TKO600 or T56 install into a 68-70 B Body? [Re: 67autocross]
DAYCLONA Offline
Loc: Mass
My post was in jest, seeing how long (years) some are still waiting for a transmission, never mind spare parts..lol!
But I agree with you, cut the car, it's just a machine, modify the piss out of it...
#2458809 - 02/28/18 10:11 AM Re: Any cutting for TKO600 or T56 install into a 68-70 B Body? [Re: DAYCLONA]
moparx Online   content
Dreaming of implants
Loc: north of coder
i agree ! if NO modifications are allowed, that means no change over to disc brakes, or alternator bypass upgrades to the electrical system, better wiper blades, etc. and you shouldn't want an o.d. in the first place. it's only sheet metal you are cutting. get the MOST bang for your buck transmission wise. you will only LOVE it that much more, and in the future, you or the next owner can restore it back to stock. then wonder why it is not as much fun to drive, or just sit around [the campfire] and admire it in the "museum".
beer
#2462430 - 03/07/18 01:49 AM Re: Any cutting for TKO600 or T56 install into a 68-70 B Body? [Re: BigHemiVegas]
RylisPro Offline
Loc: NorCal
I was updating my website and found that there are actually 6 different part numbers for the T56 Magnum
-Part# TUET11009 hydraulic clutch
-Part# TUET11010 mechanical clutch
2.66 1st
1.78 2nd
1.30 3rd
1.00 4th
0.80 5th
0.63 6th
2.90 Reverse
-Part# TUET11012 hydraulic clutch
-Part# TUET11011 mechanical clutch
2.97 1st
2.10 2nd
1.46 3rd
1.00 4th
0.74 5th
0.50 6th
2.90 Reverse
-Part# TUET16885 hydraulic clutch
-Part# TUET16884 mechanical clutch
2.97 1st
2.10 2nd
1.46 3rd
1.00 4th
0.80 5th
0.63 6th
2.90 Reverse
The 2.97 1st and 0.74 5th, 0.50 6th will eventually be phased out so get one while you still can!
/Drive
Instagram: @rylispro
YouTube:RylisPro
www.rylispro.com
925-214-9192
Tremec T56 Magnums & Quick Time bells
Lightened Billet Steel Flywheels
Prefix Performance
#2462456 - 03/07/18 07:34 AM Re: Any cutting for TKO600 or T56 install into a 68-70 B Body? [Re: BigHemiVegas]
JAMESDART Offline
Loc: nj
T56 is huge. I put a viper t56 in my duster in 2010. I like the way it drives and shifts but I have mixed feelings on The 2 overdrives and The .5 od. The close ratio sounds like a better option but I didn't have that choice. I'd like to regear and maybe make the .5 a little more useable. I made a whole new tunnel and modified the crossmember. I just made a separate trans crossover that mounts to the frame connectors.
#2462505 - 03/07/18 09:13 AM Re: Any cutting for TKO600 or T56 install into a 68-70 B Body? [Re: JAMESDART]
6PKRTSE Offline
Loc: Motor City
My buddy has a TKO600 in his 69' Camaro. The 5th gear overdrive is awesome in this car for freeway cruising. He is thinking about pulling it out & installing a Turbo 400 back in it since he doesn't like rowing the gears any longer. I was thinking about buying it off of him when we remove it. I wonder what would be different other than maybe shifter location to make it work in a Mopar B Body. Obviously, his clutch, pressure plate, flywheel & bell housing will not work. I am talking about just the gear box itself.
1970 Charger R/T S.E. 440 Six Pack
1970 CHALLENGER R/T, 25.5 Cert, Big Inch Alum 16 plug HEMI twin turbo.
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner.
1996 2500 RAM 488 V-10 4X4.
2012 Challenger R/T Classic.
#2462507 - 03/07/18 09:17 AM Re: Any cutting for TKO600 or T56 install into a 68-70 B Body? [Re: 6PKRTSE]
DAYCLONA Offline
Loc: Mass
The GM location is different than the 69-70 or 71-4 B body, but you could ship the tranny to SST and have them mod the case for either B body location, compare costs on used/modified over NEW from SST before you pull the trigger on a purchase
Mike
#2462833 - 03/07/18 07:28 PM Re: Any cutting for TKO600 or T56 install into a 68-70 B Body? [Re: BigHemiVegas]
clonedshaker+6 Offline
Loc: Oreland Pa
the passon 5 speed might be $5-6k or what ever it is but that is basically all you have to buy and maybe a clutch disc. if you go buy a tremec you need a cross member, drive shaft and yoke, bell housing, clutch linkage might change, a clutch, which all adds up and after all that you have trial and error making sure everything fits and driveline angles are correct. passon 5 speed is a true bolt in deal that can be done on a Saturday morning and out cruising by lunch time and keep your stock floor pans.. just my 2 cents
71 challenger 440 sixpack shaker *CLONE* (71challenger 440+6 shaker clone FAST/my HS grad present)
11.54 @ 120.2 4 SPEED on F60-15s w/ 7/32 tread
https://www.youtube.com/watch?v=fSsGc_Q2Aqw
#2462852 - 03/07/18 07:54 PM Re: Any cutting for TKO600 or T56 install into a 68-70 B Body? [Re: clonedshaker+6]
71birdJ68 Offline
Loc: Morristown Tn.
I agree, but seems like the 5 speed Passon is unavailable, so it boils down to what is the car being used for, and how much money it will cost, and skill level for the install of a TKO. If it is a manual already, and if a Passion 4 speed is good enough, all is needed is an 18 spline clutch, then plug and play. On my 4 speed at 2500, I get around 75 mph with 3:54 gears.
#2462857 - 03/07/18 07:59 PM Re: Any cutting for TKO600 or T56 install into a 68-70 B Body? [Re: clonedshaker+6]
RylisPro Offline
Loc: NorCal
Very true!
The beauty of a Tremec T56 Magnum though is that you can have it right now! Yes, there is surgey involved but it's not rocket science. The conversion can take a few weeks vs. waiting years, so buy one now and be driving by the summer.
Yes,the costs do add up but that is if you purchase at retail prices. There is no way for us small guys compete with Summit, Jeg's, SST, American Powertrain or other Elite Tremec distributors directly so I have to sell my kits at below retail just to be competitve which saves my customers in the long run.
/Drive
YouTube:RylisPro
www.rylispro.com
925-214-9192
Prefix Performance
#2463072 - 03/08/18 10:34 AM Re: Any cutting for TKO600 or T56 install into a 68-70 B Body? [Re: clonedshaker+6]
Yes but try getting your hands on one before you end up in the old folks home! laugh2
25,629 Registered Members
195,551 Topics
More missing screws: '71 B Body Rallye Cluster dash
by Fab64
12/12/18 10:46 AM
Mopar Parts Dist. Center Wins World Class Logistics Award
by Rustymuscle
12/12/18 10:46 AM
Xmas 2998450s steelies for me!
by jeff968
12/12/18 10:43 AM
BB Rod and Main Bearings
by SCATPACK 1
12/12/18 10:29 AM
