#2462296 - 03/06/18 07:54 PM Good polished alumium cleaner and wax?
Loc: Bend,OR USA
I'm putting together a hemi motor that has a set of polished cast aluminum valve covers, I had to clean them inside and out to get the polishing residue out and I need to find a good polish and wax for them to clean and protect them.
I have a can Neverdul but I'm wondering if there is better stuff to use on them help
Thanks in advance for the help up
Edited by Cab_Burge (03/06/18 07:55 PM)
#2462360 - 03/06/18 09:19 PM Re: Good polished alumium cleaner and wax? [Re: Cab_Burge]
moparjim79 Offline
Loc: Central Pa
Autosol is the best in my book for a paste, but if your looking to just spruce them up, Wenol or mothers alum polish, followed by a paste wax.
#2462394 - 03/06/18 10:39 PM Re: Good polished alumium cleaner and wax? [Re: Cab_Burge]
CrAzYMoPaRGuY Offline
Loc: Canada
i'm not a fan of NeverDull. I like all the choices Jim listed above
CrAzYMoPaRGuY
#2462454 - 03/07/18 07:10 AM Re: Good polished alumium cleaner and wax? [Re: Cab_Burge]
70HemiGTX Offline
Loc: PA
I use Wenol and Mother's metal polish. I think they both work well. Also go to the nearest truckstop. Check out their selection of aluminum polish. Truckers don't want to spend lots of time rubbing their tanks..... They have some good stuff there. Sorry I don't know the names.
#2462487 - 03/07/18 08:35 AM Re: Good polished alumium cleaner and wax? [Re: Cab_Burge]
srt Offline
Loc: $0.6k+B
Just bought and using "speedy all metal polish" on a set of american slots. Bought on-line as I could not find it near me. I first found it at a truck stop. I believe it's made from buffing compound in a solvent based wax. I used it with 4-0 steel wool, and then buffing with nubs.
Pretty easy to use and I like that it's a solvent based product. I'd be careful using wax on valve covers due to heat issues.
There is a product I've seen, but have not tried called opti metal coat that a local paint shop has literature on, but no reports of buyers. Seems it's like a chemical clear coat that bonds to the metal and is great for non-cleared (open) aluminum.
#2462695 - 03/07/18 02:50 PM Re: Good polished alumium cleaner and wax? [Re: Cab_Burge]
moparjim79 Offline
Loc: Central Pa
I have used meguires paste wax on not only chrome, but polished alum valve covers throughout the years with zero issues. Im only speaking from my experiences. Quite honestly, once you use a higher grade polish, most people are pretty much done at that point and are satisfied with the end results.
#2462726 - 03/07/18 03:58 PM Re: Good polished alumium cleaner and wax? [Re: Cab_Burge]
Cuda340 Offline
Loc: Wheatfield, NY
Flitz is good stuff. http://www.flitz.com/
#2462729 - 03/07/18 04:06 PM Re: Good polished alumium cleaner and wax? [Re: Cuda340]
RS23U1G Offline
Moparts Torchbearer
Loc: Detroit
Originally Posted By Cuda340
Flitz
Have had a tube of it for a lot of years...
Mostly for the shootin' irons...
Along with a can of Nevr-Dull...
There's a lot of aluminum-specific products out there today...
#2463058 - 03/08/18 10:08 AM Re: Good polished alumium cleaner and wax? [Re: moparjim79]
crlush Offline
Loc: Michigan
iagree
#2463080 - 03/08/18 10:41 AM Re: Good polished alumium cleaner and wax? [Re: Cab_Burge]
71birdJ68 Offline
Loc: Morristown Tn.
Cab, just a suggestion. What about some sort of coating, say like what they do to headers. Polishing and rubbing gets old fast.
#2463096 - 03/08/18 11:25 AM Re: Good polished alumium cleaner and wax? [Re: Cab_Burge]
MI_Custumz Offline
Loc: Port Huron, Michigan
Can you use Autosol on chrome? I see some different versions and some say not to use on certain things.
#2463118 - 03/08/18 12:09 PM Re: Good polished alumium cleaner and wax? [Re: 71birdJ68]
Loc: Bend,OR USA
I had to clean them up inside with solvent to get the polishing residue out of them, they where wrinkle black paint bake on originally. The solvent wiped off okay with a old tee shirt but I want to make sure they are clean once I'm done working on it after the dyno testing is done.
Thanks to all of you on helping me on this up bow
Pay it forward grin
#2463131 - 03/08/18 12:28 PM Re: Good polished alumium cleaner and wax? [Re: MI_Custumz]
moparjim79 Offline
Loc: Central Pa
I would not standard equipment autosol on chrome, it may scratch the finish.....and the O.P. is talking about polished aluminum.
#2463589 - 03/09/18 05:20 AM Re: Good polished alumium cleaner and wax? [Re: Cab_Burge]
toplescuda Offline
I Whine
Loc: poplar bluff mo.
If they have al ready had a high polish put on them. Do not touch with never dull. Ya be sorry. If ya had alum that has never had polish work on them. Never dull is a good start. But the wool fibers will make it look like ya sanded it with 1000 grit sand paper. I did a spot on a tunnel ram with a mirror shine. I was mad after. And had to have it redone/touched up
Mother mag wheel polish a old t shirt and elbow work. Will make huge differance. If your still getting black. Then it's still pulling dirt out of the pores of the metal
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
#2463963 - 03/09/18 05:26 PM Re: Good polished alumium cleaner and wax? [Re: Cab_Burge]
mopars4ever Offline
Loc: md
I have tried most of the polishes listed above and I always seem to go back to Mothers Mag Wheel polish.
25,351 Registered Members
190,303 Topics
Weekend getaway......... The Outlaws
by B3422W5
40 minutes 24 seconds ago
WIW - NOS 70-71 E-Body Wiper Motor
by floyd
Today at 09:49 AM
58 dodge panel truck
by CARMAN
Today at 09:34 AM
50 plymouth
by CARMAN
Today at 09:32 AM
