#2456632 - 02/24/18 10:29 AM Setting timing?
dodge turbo Offline
Loc: Dirty Dena, Maryland
So im coming from small block stuff with a distributor.
I want to dive into gen3 stuff and I cant find the timing stuf anywhere.
I would be running the Hemi MSD box for ignition. My question is how do you set
Initial timing?
Sorry if I sound dumb AF but ive read and read and cant find this answer
Thanks !
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
#2456638 - 02/24/18 10:35 AM Re: Setting timing? [Re: dodge turbo]
sam64 Offline
Loc: okla.
I think the hemi 6 comes with a base timing curve in it.then you either buy the MSD hand held programmer of use a lap top to make adjustments.it is easier to use lap top than the hand held.
10.86@123
#2456775 - 02/24/18 02:10 PM Re: Setting timing? [Re: dodge turbo]
biff426 Online   content
Loc: Delaware
You will need a laptop and you download the MSD software the hemi 6 will plug into your laptop (you will need a serial to USB adapter ) and you setup the timing there I don’t think it comes with a curve I can’t remember but the mad guys are good and can walk you through the setup
#2456825 - 02/24/18 03:10 PM Re: Setting timing? [Re: dodge turbo]
dodge turbo Offline
Ok gotcha. Very similar to my 6al2 then
Didnt know if anything on the motor to set initial timing like you
Would with adjusting a dizzy ya know.
Ive read timing numbers are very low as compared to a small block?
#2456843 - 02/24/18 03:34 PM Re: Setting timing? [Re: dodge turbo]
Loc: Delaware
No 22-25 degrees total is all you need
#2461739 - 03/05/18 07:53 PM Re: Setting timing? [Re: biff426]
ahy Offline
Loc: IN
In case you have moved or changed sensors or even if you haven't, its a good idea to check with timing light after getting her running.
First check timing marks for accuracy with the positive stop method. Then put a light on idling and see what you have. Ideally set up a "timing tune" with timing fixed at something like 15 degrees and verify that is what you have with a light.
25,622 Registered Members
195,495 Topics
Charger cl Dallas
by stumpy
12/10/18 11:58 AM
eBay motors 10% off today
by Silver70
12/10/18 11:48 AM
MAY 17-18, COLUMBUS, OH, The Chrysler Power Classic
by moparts
12/10/18 11:10 AM
Feb 23rd COLUMBUS, OH, 24th Winter Classic Motorsports Expo
by moparts
12/10/18 11:08 AM
