68 Barracuda Trunk Trim #2461639
03/05/18 07:59 PM
03/05/18 07:59 PM
Tulsa OK
Bad340fish Offline OP
Tulsa OK
Are the top and bottom trunk trim pieces on a 68 Barracuda the same? I know the mounting hardware looks different for top and bottom but I do not know if the trim pieces are the same. I have a few pieces of trim but no hardware is on them to help determine where each might go. Thanks
68 Barracuda Formula S 340
Re: 68 Barracuda Trunk Trim [Re: Bad340fish] #2461720
03/05/18 10:36 PM
03/05/18 10:36 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
hi bad, the upper trunk trim is part # 3004 225 . the lower trunk trim is part # 3004 236 . and as you said, mounting hardware is also different for top vs bottom. ronnie
Re: 68 Barracuda Trunk Trim [Re: Bad340fish] #2461748
03/05/18 11:25 PM
03/05/18 11:25 PM
Tulsa OK
Tulsa OK
Thank you sir, I will dig out my trim and see what I have.
Re: 68 Barracuda Trunk Trim [Re: Bad340fish] #2461975
03/06/18 01:19 PM
03/06/18 01:19 PM
Woodbridge
Tommy The Chryco Offline
Woodbridge
I may have a few extra hardware pieces let me know if you want me to double check.
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
Re: 68 Barracuda Trunk Trim [Re: Tommy The Chryco] #2462073
03/06/18 05:01 PM
03/06/18 05:01 PM
Tulsa OK
Tulsa OK
Thank you for the offer, Classic sells a new set of hardware for a fair price so once I line my trim out I will order from them to have a full set.
