Simple question , Valve springs suggestions for a stock RB #2461503
03/05/18 03:12 PM
03/05/18 03:12 PM
Janesville, WI
P
polarconvert Offline OP
P
Janesville, WI
I am pulling my stock 70k mile 383 4V, RV cammed heads. I want to replace the valve springs and seals. What would you suggest I use and where is a good place to purchase them? thanks for your help.
Re: Simple question , Valve springs suggestions for a stock RB [Re: polarconvert] #2461515
03/05/18 03:30 PM
03/05/18 03:30 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
If it's a stocker, just go to the local auto parts store and order a factory replacement.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: Simple question , Valve springs suggestions for a stock RB [Re: polarconvert] #2461580
03/05/18 05:43 PM
03/05/18 05:43 PM
Any decent cam company springs for a B/RB Mopar cam with up to .525 lift should work fine, I shoot for 125 Lbs. minimum on the seats and from 300 to 350 lbs. opened at .484 lift on the valves up scope
Some of the cheaper over the counter auto part stores replacement valve springs aren't worth having or using down twocents
Re: Simple question , Valve springs suggestions for a stock RB [Re: Cab_Burge] #2461640
03/05/18 08:01 PM
03/05/18 08:01 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
911-16 comp cams springs. $94 at summit.
Re: Simple question , Valve springs suggestions for a stock RB [Re: polarconvert] #2461928
03/06/18 11:29 AM
03/06/18 11:29 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Unless your 383 is nearly 60 years old, it's not an RB.
For springs it doesn't matter but it's relevant elsewhere.
Boffin Emeritus
