A&A 727 trans. blanket #2461011
03/04/18 06:06 PM
03/04/18 06:06 PM
Wisconsin
StageIII Offline OP
StageIII  Offline OP
Wisconsin
Has anyone used a trans. blanket from A&A? Was wondering how well it fit, and who makes it for them? It's going in a '67 b body.
Re: A&A 727 trans. blanket [Re: StageIII] #2461415
03/05/18 12:31 PM
03/05/18 12:31 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I like my blanket. It wasn’t A&A. I think it was RCI. Fit fine, but the shift and kick down linkages can be an issue. I made a small guard to hold the blanket off the levers.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: A&A 727 trans. blanket [Re: StageIII] #2461419
03/05/18 12:34 PM
03/05/18 12:34 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Does anyone recertify blankets or do you just have to throw them away every two years?
Re: A&A 727 trans. blanket [Re: 340Cuda] #2461436
03/05/18 12:58 PM
03/05/18 12:58 PM
Minn
SportF Offline
SportF  Offline
Minn
Do they "expire"?
Also, to avoid linkage issues, wrap the blanket around the torsion bar. You may need a strap, bolted to the dust cover, to keep it off the headers. But this is the best way to install a blanket.
Re: A&A 727 trans. blanket [Re: StageIII] #2461442
03/05/18 01:12 PM
03/05/18 01:12 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Yes the SFI certification is only good for two years on blankets, five years on rigid shields.
Re: A&A 727 trans. blanket [Re: StageIII] #2461745
03/05/18 11:17 PM
03/05/18 11:17 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
I ran a A&A blanket back a few years ago, good heavy duty blanket at that time, dont know if they still have the same source. Had really nice strap and clip arangment
Re: A&A 727 trans. blanket [Re: StageIII] #2476241
04/02/18 06:52 PM
04/02/18 06:52 PM
NE. Ohio, USA
RHB Offline
RHB  Offline
NE. Ohio, USA
If your running fender well headers robinhoodblankets.com has the complete solution. They are also working on under chassis headers blankets and one for the 727 push button transmission.
Re: A&A 727 trans. blanket [Re: 340Cuda] #2476694
04/03/18 11:20 AM
04/03/18 11:20 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I have since learned that Stroud Safety will recertify their blankets. I don't know about other companies but I know not all will do this.
