How to adjust speed of Dash Clock?
#2460584
03/03/18 07:26 PM
03/03/18 07:26 PM
Posts: 6,224 JERSEY
RJS
JERSEY
1971 Super Bee Rallye dash with clock. I have the clock apart and let it run all night on a battery. I find the clock is FAST, go figure it is a 383 4 speed!!! The only u-tube video I found so far was a Ford clock with points and there was a lever to slide one way or the other. I can't seem to find what I need to do though with this clock. Any help would be appreciated. Thanks Ron
Re: How to adjust speed of Dash Clock?
[Re: RJS]
#2460706
03/04/18 01:50 AM
03/04/18 01:50 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
the clock is selfadjusted everytime you move it... get it backwards will get it slower, get it forward will get it faster. Untill get it right on speed and time
Of course, is not an inmediate action. It happens as long it gets correctly adjusted. It can be maybe 10 times or even 20 times LOL.
[Re: RJS]
#2461132
03/04/18 08:57 PM
03/04/18 08:57 PM
NachoRT74
Valencia, España
( deleted, double reply )
[Re: RJS]
#2461134
03/04/18 08:58 PM
03/04/18 08:58 PM
NachoRT74
Valencia, España
Chasis is grounded to the cluster housing. Prong must get positive. I'm pretty sure make it reversed on bench will work the same, but on car is just like that.
[Re: NachoRT74]
#2461256
03/05/18 12:29 AM
03/05/18 12:29 AM
Posts: 6,224 JERSEY
RJS
JERSEY
actually should go to the black end of the ammeter. All loads on the car must be running to the black side of ammeter Service manual I read said RED side??? Ron
[Re: RJS]
#2461396
03/05/18 11:31 AM
03/05/18 11:31 AM
NachoRT74
Valencia, España
well... 71 diagram for back of rallye cluster ( sorry pic is tiny and hard to read, but still can be read on a close up ) .... get it to the red side will work too and the load the clock sucks out is minimal... just not the correct side On standard cluster, and on the rest of clusters kind where the clock is not sourced with a jumper wire from ammeter, the source is from fuse box, which is powered from black side of ammeter. The red side just must get the wire straight from the battery on all cars, nothing more, nothing else. With an ammeter on car NOTHING must be sourced between ammeter and battery, and NOTHING must be sourced from batt post either. The ammeter must be read JUST the battery status, so anything sourced from this side of the line will disturb the load reading status and even overload the system. Once again, the clock is something that could be even obvioused, because it means allmost nothing to the system, but, just in case and for correctness.
[Re: RJS]
#2461404
03/05/18 11:55 AM
03/05/18 11:55 AM
NachoRT74
Valencia, España
I moved that little slider by the main spring and so far hour by hour it is accurate. Ron thats a nice way to do it on bench with clock dissasembled . While on car that slider/lever is moved by the adjusting shaft everytime you adjust ( by little steps )
[Re: RJS]
#2461405
03/05/18 11:57 AM
03/05/18 11:57 AM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
My preference is everything in the dash MUST work. I had 3 clocks,two good used ones,and NOS working clock. One by one they eventually died AFTER they were installed. The NOS one the contacts stuck and POOF smoke from the dash!!
I had enough of the old points type clocks. After re and re the dash several times,I went Quartz movement. Done.
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
