516 Heads On Truck 440 #2458911
02/28/18 03:16 PM
02/28/18 03:16 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline OP
elmor353  Offline OP
E
I am planning on rebuilding the 440 in my truck and I have a set of 516 heads that have 1.74 exhaust valves already installed. I am curious if anyone has cc'd a set and knows what size the chambers are. I don't have the equipment to cc them myself. I am guessing they are around 80cc's? This engine has standard bore flat top pistons that are .070 in the hole and Summit's 6400 cam with .445 in .466 ex and 214, 224 duration @ .050. Running the numbers on Summit's compression calculator, gives me a ballpark figure of 9.6 using a .020 steel head gasket. It will never see anything over 5000 rpm. Also curious if anyone sees a problem with this combo for my street truck?
Re: 516 Heads On Truck 440 [Re: elmor353] #2458918
02/28/18 03:24 PM
02/28/18 03:24 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
516 heads are approx 84cc
Re: 516 Heads On Truck 440 [Re: elmor353] #2458962
02/28/18 05:06 PM
02/28/18 05:06 PM
s. e. pa.
calrobb2000 Online content
calrobb2000  Online Content
s. e. pa.
hi
cut the heads .020 and your combo sounds good to go !
Re: 516 Heads On Truck 440 [Re: elmor353] #2459038
02/28/18 07:46 PM
02/28/18 07:46 PM
Any animal supply stores near you? If so a 50 CC horse syringe can be used to CC heads, with a little patience work scope That and a 5x5 inch square of plexiglass or lexan or any clear plastic works with a 1/4 inch hole in it. I use a set of head stands to put the heads in on the bench and then level the heads front to back and cock the head up so the spark plug hole is higher than the cam side of the head and some chassis grease to seal the plastic square to the head to make it hold the rubbing alcohol with food dye in it to CC the chambers up scope
How thick is the outer head bolt bosses on your 516 heads now ?
Re: 516 Heads On Truck 440 [Re: elmor353] #2459084
02/28/18 09:54 PM
02/28/18 09:54 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
My 65 516 heads came in around 75cc when I measured them.
Re: 516 Heads On Truck 440 [Re: Cab_Burge] #2459151
02/28/18 11:44 PM
02/28/18 11:44 PM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
Cab, I don't post much, mostly lurk, but I truly enjoy reading you. You make more sense than many on here. We may have even seen each other at LACR back in the 80-90's from what you have stated in some of your history.
Pat
" The last official act of any goverment, is to loot the treasury" George Washington
Re: 516 Heads On Truck 440 [Re: zzyzxpat] #2459154
02/28/18 11:47 PM
02/28/18 11:47 PM
I have made more than one pass at LACR whistling
Re: 516 Heads On Truck 440 [Re: Cab_Burge] #2460231
03/02/18 11:24 PM
03/02/18 11:24 PM
E
elmor353 Offline OP
elmor353  Offline OP
E
Cab, what kind of thickness numbers do the outer head bolt bosses run from the factory? If they are a standard size to begin with, then any deviation from that number could mean they have been cut over the years?
Re: 516 Heads On Truck 440 [Re: elmor353] #2460438
03/03/18 12:50 PM
03/03/18 12:50 PM
moparx Offline
moparx  Offline
i believe around 1" ? shruggy others should confirm this if close.
beer
Re: 516 Heads On Truck 440 [Re: moparx] #2460502
03/03/18 02:59 PM
03/03/18 02:59 PM
beer
iagree scope
Re: 516 Heads On Truck 440 [Re: Cab_Burge] #2460848
03/04/18 01:06 PM
03/04/18 01:06 PM
moparx Offline
moparx  Offline
thanks for the conformation cab. up i wasn't sure my foggy old mind was working correctly.
beer
Re: 516 Heads On Truck 440 [Re: elmor353] #2461003
03/04/18 05:56 PM
03/04/18 05:56 PM
IL
furious70 Offline
furious70  Offline
IL
I've swapped 1.74 prepped 516's where 452's were and been disappointed. The cr bump didn't overcome the flow loss
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: 516 Heads On Truck 440 [Re: furious70] #2461059
03/04/18 07:39 PM
03/04/18 07:39 PM
E
elmor353 Offline OP
elmor353  Offline OP
E
Like I said earlier, this engine will never see more than 5000 rpm. I'm thinking of low to mid-range torque. I have 452's,346's and 906 heads I could use, I just wanted to use the 516's. I know they don't flow like a set of 915's would, but I'm not trying to extract a ton of horsepower from it, just torque.
