Re: Caltracs/Mono-Leafs - Shock combo and results
[Re: Nitrofish]
#2460695
03/04/18 01:27 AM
03/04/18 01:27 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I have the caltrak setup and started with the Rancho 5 way adjustable.They did not work that well for me so after a few years I was looking at better shocks and liked the way Vi-King took the the time to make the sale and I bought all 4.I can tell you that I am hooking now.The only adjustment I make was one adjustment on the cal trak when the car started going right.That turned out to be broken spring perch when on the next pass the car went right,,,,,,,right onto the marbles. After that I tightened the Vikings one time.I have been so busy getting the 2 carbs right that if it hooked and went straight I have NOT tuned the rear. Best 60 so far is a 1.42 with a 6.0 1/8 @ 117 and finished with a 9.3 @ 147.75. 1963 b body now at 3700 with me in it.Buy the best shocks you can afford!
[Re: hemi-itis]
#2463067
03/08/18 01:30 PM
03/08/18 01:30 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
3800+ lb. E body w/ 800+ hp hemi (all motor) 295-65 drag radial, footbraking Cal-Tracs in bottom hole, 1/4 turn preload both sides. Rancho 9 ways on rear set on 9. Old Lakewood 90/10 shocks up front. 1.320 sixty foot best running mid 9s at 140 mph.
Tried the Calvert 90/10 front shocks for a while. Way looser than the old Lakewoods. Car refused to hook...lifted too fast and unloaded the rear. Put the Lakewoods back on and instantly hooked again.
When I added nitrous I went to the D/A Viking shocks. Much better, but still tuning them.
[Re: ScottSmith_Harms]
#2463189
03/08/18 05:30 PM
03/08/18 05:30 PM
Posts: 4,457 Washington
madscientist
Washington
[quote=ScottSmith_Harms]Just curious, how does lifting too fast unload the rear? [/quote
Either it hits the front travel limiters too hard or hits the wheelie bars too hard. Either or both will unload the rear tire.
[Re: Nitrofish]
#2463591
03/09/18 09:36 AM
03/09/18 09:36 AM
Posts: 2,919 A shed in England
Tig
A shed in England
We've been 1.34 @ over 3950lb with AFCO D/A's all round. We used to have the Rancho 9 ways (Rear) and comp engineering 3 ways (Front) combo. Car would sometimes wheelie and we'd lose around .1 off the ET, not good when you're bracket racing . We also tried the Calvert front shocks and like Chip found, we also thought them too loose for a heavy car. Sold them to a guy who put them on a much lighter A body (Duster IIRC), they had better results. We've also had the AFCO's re-valved by Menscer as we basically ran out of adjustment on the rear extension damping. This was done on front and rears. We've only done 6 passes since and now we're chasing a bog on the tunnel ram, we were getting there but we ran out of race season . Data shows the car is a lot more consistent with the D/A shocks. HTH's
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
