#2460493 - 03/03/18 11:32 AM 2007 Durango 5.7 oil-pressure sensor
beedees Offline
replacement. Have code p520. Can any body point me to a good how-to source to do this? Thanks
#2460667 - 03/03/18 09:03 PM Re: 2007 Durango 5.7 oil-pressure sensor [Re: beedees]
Frankenduster Offline
Moparts proctologist
Loc: Granite Bay CA
I just replaced one in my 2007 Ram last week. The guy at a NAPA store suggested buying a factory part instead of aftermarket due to reliability issues. $38 at the dealer.
There are TWO senders near the oil filter. The upper one is the oil pressure sender. It is mounted horizontally and points toward the radiator. A 1 1/16" deep socket fits the hex on it. A 6 inch extension and a 1/2" drive ratchet cleared the lower radiator hose. It is fine thread so be ready for that.
The hardest part was removing the retainer to get the wire plug off. There is a sliding red plastic tab that pushes up from the bottom to release the wire plug. I used a long standard flat screwdriver.
Good luck.
#2460906 - 03/04/18 11:39 AM Re: 2007 Durango 5.7 oil-pressure sensor [Re: beedees]
Silver70 Offline
Loc: Rust Belt, SW PA
You can buy them cheaper on ebay than the dealer, but be careful who you buy from as there are exact copies with part #s and all. Don't waste your time on the cheap aftermarket ones, unless you want to redo it.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
99 Trans Am, 66 GTO, 06 Magnum RT AWD
#2460938 - 03/04/18 12:44 PM Re: 2007 Durango 5.7 oil-pressure sensor [Re: beedees]
beedees Offline
Thanks for the replies. Does anyone know if this can be done from the top?
25,488 Registered Members
193,036 Topics
rear sway bar in Cuda with Dana 60
by FJ6AAR
09/22/18 02:11 PM
70 Challenger passenger rear 1/4 patch panel
by RROD
09/22/18 01:08 PM
1986 Buick Grand National - $8900
by Soopernaut
09/22/18 12:07 PM
CLAYBARS
by Magnumguy
09/22/18 11:04 AM
