woho it runs
#245997
03/07/09 05:22 PM
03/07/09 05:22 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
fired the car up today motor runs and sounds great took it for a quick run down the street every thing seems good trans brake worked delay box worked brakes worked. Only 2 small problems I have 3 freeze plugs leaking for some reason and I have a little to much oil pressure. It is carrying 70lbs at an idle in neutral and if I tach it up it pegs the gauge at over 100lbs Damn. I shot video but it is on an old camcorder that is 8mm tape so I have no way to post it right now. But all in all things went good I need to back the timing on the crank trigger down its a little high at 43 deg.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: woho it runs
[Re: Quicktree]
#246001
03/07/09 05:47 PM
03/07/09 05:47 PM
dusturbd340W5
Kissimmee Fl.
gauge is a new Autometer Sport Comp the pump is a Melling HV that I ported and cleaned all the flashing out of and polished up and the gauge reads off the oil filter housing. Also keep in mind this block has lifter bushings also restricted oil to cam bearings trying to keep all the oil on the crank as we could.
Re: woho it runs
[Re: dusturbd340W5]
#246002
03/07/09 09:54 PM
03/07/09 09:54 PM
dusturbd340W5
Kissimmee Fl.
any ideas on the oil pressure should I just cut a little off the srping in the pump if so how much. Thanks
Re: woho it runs
[Re: Quicktree]
#246004
03/07/09 10:46 PM
03/07/09 10:46 PM
dusturbd340W5
Kissimmee Fl.
no burn outs yet may try and fix the freeze plugs tomorrow.
Re: woho it runs
[Re: dusturbd340W5]
#246005
03/07/09 11:04 PM
03/07/09 11:04 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Pour in a can of Bars leak and take out the 50 weight oil Glad to hear she fired up... also try the timing about 34*
Re: woho it runs
[Re: MR_P_BODY]
#246006
03/07/09 11:40 PM
03/07/09 11:40 PM
dusturbd340W5
Kissimmee Fl.
I considered the stop leak and I am running 15/40 Rotella.
Re: woho it runs
[Re: dusturbd340W5]
#246007
03/07/09 11:44 PM
03/07/09 11:44 PM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
lets see the ride don
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
Re: woho it runs
[Re: Dodgem]
#246011
03/08/09 12:15 AM
03/08/09 12:15 AM
dusturbd340W5
Kissimmee Fl.
that says for a big block I am running a small block
