??? on boring 383 block #2459693
03/02/18 12:25 AM
03/02/18 12:25 AM
Bowler Wisconsin
Smoparmike Offline OP
Bowler Wisconsin
Generally is a 1970 383 block safe to bore 60 over? I know it should be sonic checked. I know each block is different core shift etc. Just wondering in general. This will be for a mild street car.
Re: ??? on boring 383 block [Re: Smoparmike] #2459780
03/02/18 04:31 AM
03/02/18 04:31 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
maby /what size is it now ?
have you considered .040 os ?
Re: ??? on boring 383 block [Re: Smoparmike] #2459790
03/02/18 05:50 AM
03/02/18 05:50 AM
Why take a chance work
Are you filling lucky whistling
Re: ??? on boring 383 block [Re: Cab_Burge] #2459813
03/02/18 09:48 AM
03/02/18 09:48 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Does it need to go .060 over? I always use the minimum over bore. I think the rigidity of the thicker cylinder wall outweighs the small cubic inch gain.
Re: ??? on boring 383 block [Re: fbs63] #2459835
03/02/18 11:03 AM
03/02/18 11:03 AM
Bowler Wisconsin
Bowler Wisconsin
Thanks for replies. Block is 30 over now. But has a pretty good ridge I would love it to only need to go .040. I'm taking to machine shop next week.
Re: ??? on boring 383 block [Re: Smoparmike] #2459864
03/02/18 12:24 PM
03/02/18 12:24 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
the ridge isn't the critical part. bore taper is. once its checked the ridge could be removed with a minial over bore.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: ??? on boring 383 block [Re: Jerry] #2459900
03/02/18 01:38 PM
03/02/18 01:38 PM
Bowler Wisconsin
Bowler Wisconsin
I didn't know that. Makes sense though.
Re: ??? on boring 383 block [Re: Smoparmike] #2459931
03/02/18 03:00 PM
03/02/18 03:00 PM
Usually if you can feel the ridge, especially a big one, it will need more than .030 whiney I hope not, let us know what they find luck
Re: ??? on boring 383 block [Re: Smoparmike] #2480126
04/09/18 06:45 PM
04/09/18 06:45 PM
Bowler Wisconsin
Bowler Wisconsin
Block needed to go.060. Would not clean up at.040. Had it sonic checked and they are putting in one sleeve. This is for my kids car. Bought this motor when he was 13. Put in car and had oil pressure problems. Took it a part not a good as I would have hoped for. Live and learn. He turns 18 next week so hopefully this will be the last of problems.
