tips for tightening pinion nut 742 #2459429
03/01/18 03:15 PM
03/01/18 03:15 PM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
I need to put the pinion nut back on with some loctite and 250 lbs. It's in the car.
Problems right now-- it will be tricky to get my torque wrench in there for 250 ft lbs (the mufflers and ground are in the way), and the wheels turn even with parking brake. I can get a long breaker in there OK.
So I've read some people just hit it with an impact gun (not knowing actual torque), others use something to hold the yoke.
I was thinking of setting the back tires on ramps, with front tires chocked, to keep them from moving but still have the car up in the air.
Just hoping for tips so I can get under there and do it once before having to clean loctite off because something not allowing me to get it on tight the first time. Thanks for ideas.
Re: tips for tightening pinion nut 742 [Re: Exit1965] #2459450
03/01/18 04:13 PM
03/01/18 04:13 PM
Chicago
PurpleBeeper Offline
Chicago
I saw somebody on FBBO that welded up a tool to do this. Basically, it's a metal plate, maybe 5"x6"or so with holes drilled into it that line up with the pinion yoke. It also had a large hole cut in the center to allow access to the pinion bolt.
That plate is welded to a 3ft. bar. You use the rear u-joint bolts (or u-bolts) to bolt to the plate, lift the car slightly so you can get under it, torque (or impact) the pinion bolt & the long bar hits the ground so the rear yoke can't turn.
I've never seen one for sale, just this home-built one.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: tips for tightening pinion nut 742 [Re: Exit1965] #2459451
03/01/18 04:16 PM
03/01/18 04:16 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Do not put the car on ramps & tighten the nut, sounds VERY dangerous, I use an impact when in your situation.
Re: tips for tightening pinion nut 742 [Re: Exit1965] #2459495
03/01/18 05:55 PM
03/01/18 05:55 PM
CA
crackedback Online content
crackedback  Online Content
CA
Re: tips for tightening pinion nut 742 [Re: crackedback] #2459504
03/01/18 06:16 PM
03/01/18 06:16 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I get the whole car up on stands.
Put a large pipe on the handle of a big pipe wrench placed on the yolk.
Spin it against the floor.
Now you can tighten the yolk nut.
Nice tool above, same concept applied.
I have mechanical Aptitude.
I can screw up anything.
Re: tips for tightening pinion nut 742 [Re: bboogieart] #2459539
03/01/18 06:55 PM
03/01/18 06:55 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
iagree Jam a pipe wrench against the ground and torque wrench to specs.
Re: tips for tightening pinion nut 742 [Re: Exit1965] #2459563
03/01/18 07:53 PM
03/01/18 07:53 PM
BDW Offline
BDW  Offline
Doesn't the pipe wrench [censored] up the yoke?
Re: tips for tightening pinion nut 742 [Re: Exit1965] #2459576
03/01/18 08:30 PM
03/01/18 08:30 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Nope. The pipe wrench clamps over the square ear of the yoke from the side so you have square bite to square ear. You could use an adjustable wrench if you had one big enough.
Re: tips for tightening pinion nut 742 [Re: Exit1965] #2459595
03/01/18 09:29 PM
03/01/18 09:29 PM
AndyF Offline
AndyF  Offline
I make a universal tool for Mopar yokes that fits on a 3/4 drive breaker bar.
http://arengineering.com/products/rear-end-yoke-holder/
Re: tips for tightening pinion nut 742 [Re: stumpy] #2459614
03/01/18 09:59 PM
03/01/18 09:59 PM
IN
ahy Offline
ahy  Offline
IN
I have used this technique also. Little to no damage and any small marks from the pipe wrench are cosmetic.
Re: tips for tightening pinion nut 742 [Re: crackedback] #2459627
03/01/18 10:47 PM
03/01/18 10:47 PM
crlush Offline
crlush  Offline
Originally Posted By crackedback
I made a set for large and small yoke, they work great.
Re: tips for tightening pinion nut 742 [Re: Exit1965] #2459648
03/01/18 11:22 PM
03/01/18 11:22 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
A lot of us don't have the stuff to make a very nice tool like that.
Re: tips for tightening pinion nut 742 [Re: Exit1965] #2459730
03/02/18 01:12 AM
03/02/18 01:12 AM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
Thanks guys. My dad lent me a nice long pipe wrench that I think will reach the floor and do the trick.
Those tools look great.
Re: tips for tightening pinion nut 742 [Re: CSK] #2459739
03/02/18 01:21 AM
03/02/18 01:21 AM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Set the parking brake, and block the tires.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: tips for tightening pinion nut 742 [Re: Exit1965] #2459756
03/02/18 02:15 AM
03/02/18 02:15 AM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
I made a tool just like the one in crackedback's picture. Since you're just right down the road from me, you're welcome to use it.
What u-joints do you have?
Re: tips for tightening pinion nut 742 [Re: Exit1965] #2459767
03/02/18 03:01 AM
03/02/18 03:01 AM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
Hi Mopowers, thanks for the offer! It's got the small u joints, but the job is done.
I tried having my dad step on the brake and set the e-brake, but there was enough flexion in there that we actually had to hold the yoke still. So we ended up putting a pipe wrench on it with the end of the pipe wrench in a jack stand base. The 2 of us pushing and pulling were able to get a click at 250 lbs.
Re: tips for tightening pinion nut 742 [Re: Exit1965] #2459772
03/02/18 03:10 AM
03/02/18 03:10 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Lucky enough to have the real thing.
Re: tips for tightening pinion nut 742 [Re: 62maxwgn] #2459776
03/02/18 03:39 AM
03/02/18 03:39 AM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Cool! Is the other end for axle end play?
Re: tips for tightening pinion nut 742 [Re: A990] #2459850
03/02/18 11:34 AM
03/02/18 11:34 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Yep !
Re: tips for tightening pinion nut 742 [Re: stumpy] #2459860
03/02/18 12:15 PM
03/02/18 12:15 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I don't know. One of my friends was setting up a Ford 9" and it would have been a real show without a tool like that. We took a piece of 1/4" scrap plate, cut the hole with a holesaw, drilled the yoke pattern and welded a piece of square tube for a handle. Took us about 25 minutes start to finish with stuff that I would guess 75% of the members have in their shop/garage. shruggy
