Anybody recognize these?
#2458611
02/27/18 10:48 PM
02/27/18 10:48 PM
Posts: 1,443 central ohio
nss guy
central ohio
This picture is from 2005, I was going thru an old thumb drive and came across them.
Re: Anybody recognize these?
[Re: nss guy]
#2458709
02/28/18 02:51 AM
02/28/18 02:51 AM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The answer should reveal itself if you saw the ex side of the head.
Looks like the raised port version of the Bulldog head.
[Re: fast68plymouth]
#2458742
02/28/18 10:17 AM
02/28/18 10:17 AM
nss guy
central ohio
Looks like the raised port version of the Bulldog head. . Winner, Those were a set of bulldog heads I ran back in 2005.
[Re: nss guy]
#2458810
02/28/18 01:11 PM
02/28/18 01:11 PM
fast68plymouth
So. Burlington, Vt.
The reason I mention the ex side is, the ones I've worked on had "Bulldog Performance" cnc'd into the outer edge of the head bolt boss.
These are really pretty similar to the TF heads, but the TF heads executed it better.
#2459252
03/01/18 04:37 AM
03/01/18 04:37 AM
Posts: 771 Btween a rock and a hard place
moparlulu
These are really pretty similar to the TF heads, but the TF heads executed it better. they must be! Switched from a set of Bradshaw himself prepped Bulldogs to a set of 240 tf's, didn't gain a thing but spending 2000.00 dollars.
