Re: Ritter Block
[Re: Biginchmopar]
#2455159
02/21/18 04:51 PM
02/21/18 04:51 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
Well you cant argue wanting the biggest bore possible as bore is HP. But weight is also a factor, any idea what the weight difference between the two are? Just curious
Re: Ritter Block
[Re: Biginchmopar]
#2455177
02/21/18 05:33 PM
02/21/18 05:33 PM
Al_Alguire
Las Vegas
So in my mind you would need to be able to making enough power to overcome the weight difference to justify the extra weight. Why I have chosen aluminum BB's over the iron brethren. The big difference is the weight difference is larger but the bore potential is the same. BUt that is the logic behind why the Vette has an aluminum SB in it, but we are not limited to a smaller bore because of that choice.
Re: Ritter Block
[Re: Biginchmopar]
#2455327
02/21/18 10:43 PM
02/21/18 10:43 PM
Posts: 6,150 Melbourne , Australia
LA360
The Ritter block in it's aluminium form is the same casting as the iron version. It's not a specific pattern, I'm not even sure if they've allowed for the different shrinkage rates of the two materials. I'd want to see some more material in the casting, ribs etc. That's just a personal preference of mine. I think for most of us, the weight saved in an aluminium block is more of a benefit. Those chasing every last piece of HP, in a car they have to add ballast too, you'd go Iron.
Alan Jones
Re: Ritter Block
[Re: LA360]
#2455347
02/21/18 11:22 PM
02/21/18 11:22 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
A lot of guys go with aluminum for ease of repairing the block when all heck break loose. Lots of junk mega blocks still laying around
Re: Ritter Block
[Re: Biginchmopar]
#2455385
02/22/18 12:42 AM
02/22/18 12:42 AM
Posts: 103 Kansas, Topeka
69 lawndart
Kansas, Topeka
Mine is 4.155", I would say 4.185" is about max bore, I think the prototype aluminum block is 4.185". There is a lot of material around the cylinders in this block. I was told that the castings were the same. The weight on mine is 107 lbs. with sleeves and main caps. I need to add for a NA motor.
Re: Ritter Block
[Re: Jason B]
#2458487
02/27/18 05:35 PM
02/27/18 05:35 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
We did exactly that... we opened up the cam tunnel to increase drain back. We are going to run a similar setup as White Dart using a Daily wet sump.
White Dart is a great source of help and information. I will be starting a thread as soon as ours starts going back together! Hopefully will be posting pictures in a few weeks good luck and if you need any help let us know. Thanks Jason! I'll be in touch for sure, lots of little details need to be addressed. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
Re: Ritter Block
[Re: Biginchmopar]
#2458490
02/27/18 05:43 PM
02/27/18 05:43 PM
Al_Alguire
Las Vegas
Hard to go wrong with the QMP crew
Re: Ritter Block
[Re: Al_Alguire]
#2458555
02/27/18 08:05 PM
02/27/18 08:05 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I'm going to say good choice.. it will require some patience because they are very busy but I assure you it will be worth the wait.. when you get their since you're a paying customer ask for a tour of the shop.. you will be surprised at the names on blocks and boxes of parts that you see.. everything from shops that say they do everything in house to maybe even some top 10 Pro Stock teams. I know you had some other options on block transportation.. but definitely worth a field trip
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: Ritter Block
[Re: WHITEDART]
#2459577
03/01/18 08:34 PM
03/01/18 08:34 PM
LA360
And for those that know about honing They made a substantial investment (around $100K) in their honing equipment. Definitely a higher end machine shop
Alan Jones
Re: Ritter Block
[Re: LA360]
#2459579
03/01/18 08:45 PM
03/01/18 08:45 PM
WHITEDART
bean town ....Ca
And for those that know about honing They made a substantial investment (around $100K) in their honing equipment. Definitely a higher end machine shop I think you meant to say hone head and diamonds ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) .. and actually I think that was only for the old head and stones. They have substantially better stuff than that now.. I think if you have a Target temperature that you can operate the Motor Inn he can hone the block at that temperature..
Re: Ritter Block
[Re: Al_Alguire]
#2459584
03/01/18 08:56 PM
03/01/18 08:56 PM
Thumperdart
State of confusion
Hard to go wrong with the QMP crew I would of given Pettis a call unless Jason doesn't have the experience w/those......... ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
