Page 4 of 5 1 2 3 4 5
Re: Ritter Block [Re: Biginchmopar] #2455154
02/21/18 04:40 PM
02/21/18 04:40 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Is the Ritter block Siamese ?
Is the max bore size 4.250 ?
Re: Ritter Block [Re: Biginchmopar] #2455156
02/21/18 04:42 PM
02/21/18 04:42 PM
Carson City, Nevada
Biginchmopar Offline OP
Carson City, Nevada
It is Siamese and I think they say 4.220"
Re: Ritter Block [Re: Biginchmopar] #2455159
02/21/18 04:51 PM
02/21/18 04:51 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well you cant argue wanting the biggest bore possible as bore is HP. But weight is also a factor, any idea what the weight difference between the two are? Just curious
Re: Ritter Block [Re: Al_Alguire] #2455168
02/21/18 05:15 PM
02/21/18 05:15 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
About 100lb
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Ritter Block [Re: Biginchmopar] #2455177
02/21/18 05:33 PM
02/21/18 05:33 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
So in my mind you would need to be able to making enough power to overcome the weight difference to justify the extra weight. Why I have chosen aluminum BB's over the iron brethren. The big difference is the weight difference is larger but the bore potential is the same. BUt that is the logic behind why the Vette has an aluminum SB in it, but we are not limited to a smaller bore because of that choice.
Re: Ritter Block [Re: Biginchmopar] #2455228
02/21/18 07:22 PM
02/21/18 07:22 PM
Carson City, Nevada
Carson City, Nevada
All out race car deal I would go Aluminum.
This thing is getting there quick, at least the engine part. realcrazy
beer
Re: Ritter Block [Re: Biginchmopar] #2455327
02/21/18 10:43 PM
02/21/18 10:43 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
The Ritter block in it's aluminium form is the same casting as the iron version. It's not a specific pattern, I'm not even sure if they've allowed for the different shrinkage rates of the two materials.
I'd want to see some more material in the casting, ribs etc. That's just a personal preference of mine. I think for most of us, the weight saved in an aluminium block is more of a benefit. Those chasing every last piece of HP, in a car they have to add ballast too, you'd go Iron.
Alan Jones
Re: Ritter Block [Re: LA360] #2455347
02/21/18 11:22 PM
02/21/18 11:22 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
A lot of guys go with aluminum for ease of repairing the block when all heck break loose. Lots of junk mega blocks still laying around
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Ritter Block [Re: Biginchmopar] #2455383
02/22/18 12:33 AM
02/22/18 12:33 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
It’s too bad the max bore size of the aluminum is 4.120. Does any one know the price ?
Re: Ritter Block [Re: Biginchmopar] #2455385
02/22/18 12:42 AM
02/22/18 12:42 AM
Kansas, Topeka
69 lawndart Offline
69 lawndart  Offline
Kansas, Topeka
Mine is 4.155", I would say 4.185" is about max bore, I think the prototype aluminum block is 4.185". There is a lot of material around the cylinders in this block. I was told that the castings were the same. The weight on mine is 107 lbs. with sleeves and main caps. I need to add for a NA motor.
Re: Ritter Block [Re: Cab_Burge] #2455392
02/22/18 01:07 AM
02/22/18 01:07 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Originally Posted By Cab_Burge
Be careful of what you wish for tsk whistling work
N/A iron blocks, even super charged, will run faster than the same parts in a aluminum block in the 1/4 mile in the same car weighing the same shruggy
All good Cab!
You want an aluminum block for track days and road racing. I got an all aluminum Gen3 instead. 600hp at the crank is plenty scary enough when going around a corner!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Ritter Block [Re: Biginchmopar] #2458434
02/27/18 03:40 PM
02/27/18 03:40 PM
Carson City, Nevada
Carson City, Nevada
Just a quick update. After making a few calls and talking to the guys that are way deep into these small blocks, I have decided to take the block to Quarter Mile Performance (QMP) is Southern California. They have all the tools to do what I want plus they have already worked on a few of these blocks in the past so we will get their opinion as well.
These are all good things and I'll share what we find when it is finished being machined.
Re: Ritter Block [Re: Jason B] #2458487
02/27/18 05:35 PM
02/27/18 05:35 PM
Carson City, Nevada
Carson City, Nevada
Originally Posted By Jason B
We did exactly that... we opened up the cam tunnel to increase drain back. We are going to run a similar setup as White Dart using a Daily wet sump.
White Dart is a great source of help and information. I will be starting a thread as soon as ours starts going back together! Hopefully will be posting pictures in a few weeks good luck and if you need any help let us know.
Thanks Jason!
I'll be in touch for sure, lots of little details need to be addressed. up
Re: Ritter Block [Re: Biginchmopar] #2458490
02/27/18 05:43 PM
02/27/18 05:43 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Hard to go wrong with the QMP crew
Re: Ritter Block [Re: Al_Alguire] #2458555
02/27/18 08:05 PM
02/27/18 08:05 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I'm going to say good choice.. it will require some patience because they are very busy but I assure you it will be worth the wait.. when you get their since you're a paying customer ask for a tour of the shop.. you will be surprised at the names on blocks and boxes of parts that you see.. everything from shops that say they do everything in house to maybe even some top 10 Pro Stock teams. I know you had some other options on block transportation.. but definitely worth a field trip
Re: Ritter Block [Re: WHITEDART] #2458600
02/27/18 10:10 PM
02/27/18 10:10 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
A sneak peek inside qmp North
Re: Ritter Block [Re: WHITEDART] #2458601
02/27/18 10:11 PM
02/27/18 10:11 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
And for those that know about honing
Re: Ritter Block [Re: WHITEDART] #2459577
03/01/18 08:34 PM
03/01/18 08:34 PM
LA360 Offline
LA360  Offline
They made a substantial investment (around $100K) in their honing equipment. Definitely a higher end machine shop
Alan Jones
Re: Ritter Block [Re: LA360] #2459579
03/01/18 08:45 PM
03/01/18 08:45 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I think you meant to say hone head and diamonds whistling.. and actually I think that was only for the old head and stones.
They have substantially better stuff than that now.. I think if you have a Target temperature that you can operate the Motor Inn he can hone the block at that temperature..
Re: Ritter Block [Re: Al_Alguire] #2459584
03/01/18 08:56 PM
03/01/18 08:56 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I would of given Pettis a call unless Jason doesn't have the experience w/those......... thumbs
