Heading to Indy this weekend - where to get brake lines #2458577
02/27/18 09:23 PM
02/27/18 09:23 PM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
where is the best place to get prebent brake lines. I might get stainles steel but not sure yet
Any thoughts?
Re: Heading to Indy this weekend - where to get brake lines [Re: 6T6Cuda] #2458617
02/27/18 11:09 PM
02/27/18 11:09 PM
IN
ahy Offline
ahy  Offline
IN
I used an In Line tube set and happy. Mild steel. I did modify it for an added prop valve. I prefer mild steel as it seals better and can be successfully modified with a common double flare tool.
Do you need it fixed before the trip? If so, replace the rough sections with hand bent tube. I use a 20' roll from Autozone + necessary fittings for spot repairs when needed.
Re: Heading to Indy this weekend - where to get brake lines [Re: 6T6Cuda] #2458746
02/28/18 10:48 AM
02/28/18 10:48 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
A second vote for mild steel. Stainless can be a big PIA.
Re: Heading to Indy this weekend - where to get brake lines [Re: 6T6Cuda] #2458787
02/28/18 12:29 PM
02/28/18 12:29 PM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
Thanks; I'll see what they have at the Indy swap meet and if not I'll most likely get everything from Dr Diff
Re: Heading to Indy this weekend - where to get brake lines [Re: 6T6Cuda] #2459014
02/28/18 06:59 PM
02/28/18 06:59 PM
KY
65pacecar Offline
65pacecar  Offline
KY
In Line or Fine Lines, I have had good luck with both. I agree on mild steel, much easier to deal with and avoid leaks.
