1962 DART rear disc. brake upgrade info needed? #2458271
02/27/18 10:21 AM
02/27/18 10:21 AM
6T4 Polara Offline OP
Friend has a 1962 Dart with front disc's thinking about upgrading rear to discs.
What is available and what is your experiences converting.
Has a complete later model rear end installed and 15 inch wheels.
Street driven no longer raced.
John
Re: 1962 DART rear disc. brake upgrade info needed? [Re: 6T4 Polara] #2458301
02/27/18 12:12 PM
02/27/18 12:12 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
What rear end?
Have a great day
Iowan
"obsolete is neat"
Re: 1962 DART rear disc. brake upgrade info needed? [Re: 6T4 Polara] #2458310
02/27/18 12:25 PM
02/27/18 12:25 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Doesn't matter what rear you have because Doctordiff can set you up with the good stuff.
All you have to do is have the measurements ready and tell him what your intended usage is and Cass will set you up from full race to basic cruiser.
Gus beer
64 Plymouth Savoy
Dana 60
Re: 1962 DART rear disc. brake upgrade info needed? [Re: 6T4 Polara] #2458313
02/27/18 12:26 PM
02/27/18 12:26 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Since he is still "thinking" what is the intended use, what are the current upgraded front discs, and he will need to swap out rear tapered axle set-up to do most upgrades.
