Testing gauges on 74 Charger? #2458178
02/26/18 11:49 PM
02/26/18 11:49 PM
North Carolina, USA
Silverbullet2 Offline OP
North Carolina, USA
My buddy bought a used cluster for a charger last year at Carlisle and wants to test the gauges before he puts it in the car. I know with it in the car you can ground the sender wire and the gauge will sweep full to the right. Is there a way to test with no voltage? A certain ohms resistance?
Re: Testing gauges on 74 Charger? [Re: Silverbullet2] #2458198
02/27/18 12:17 AM
02/27/18 12:17 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Re: Testing gauges on 74 Charger? [Re: Silverbullet2] #2458204
02/27/18 12:26 AM
02/27/18 12:26 AM
Andrewh Offline
Andrewh  Offline
put 2 AA batteries in series.
wire them to the gauge.
give it a sec to start moving. it isn't instant. assuming you got the pos and neg right it should move about to half way on any of them.
Re: Testing gauges on 74 Charger? [Re: Silverbullet2] #2458219
02/27/18 01:25 AM
02/27/18 01:25 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Video on bench testing for E body should work for B body too.
https://www.youtube.com/watch?v=-pKbNSStjas
Re: Testing gauges on 74 Charger? [Re: Silverbullet2] #2458262
02/27/18 08:45 AM
02/27/18 08:45 AM
North Carolina, USA
North Carolina, USA
Easy enough, thanks!
Re: Testing gauges on 74 Charger? [Re: Silverbullet2] #2458312
02/27/18 12:25 PM
02/27/18 12:25 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
or a cell phone charger. They are from 3.7, 4.5 and latelly 5 volts ( USB ones )
