What lines to vent covers to vent tank #2458082
02/26/18 09:24 PM
02/26/18 09:24 PM
Alberta Canada
E
Edge Offline OP
Edge  Offline OP
E
Alberta Canada
What hose should I use for venting my valve covers to the breather tank. Hoses will run length of vehicle as the vent tank is located in the rear. Fitting off off the valve covers are 1 1/4 od and the hose need to be flexible to work it way through the car
thanks
76 Duster work in progress
Re: What lines to vent covers to vent tank [Re: Edge] #2458106
02/26/18 10:01 PM
02/26/18 10:01 PM
Charged392 Offline
Charged392  Offline
On my scavenger setup I am using -10/12 AN pushlock line.
Re: What lines to vent covers to vent tank [Re: Edge] #2458217
02/27/18 01:10 AM
02/27/18 01:10 AM
New York
polyspheric Offline
polyspheric  Offline
New York
As big as you can fit to keep the air speed down. If possible, the line should be all downhill so the droplets don't drein back.
That would be $1,000 for bullet proof, braided tungsten carbon fiber, or $12 for PCV and hose clamps.
Boffin Emeritus
