1984 Dodge Ram Steering Wheel Issue #2457908
02/26/18 03:44 PM
02/26/18 03:44 PM
Sioux Falls SD
79volare Offline OP
79volare  Offline OP
Sioux Falls SD
Wondering if someone can help me, I got a 84 Ram plow truck, this weekend the tilt steering wheel I believe is breaking, I can move the wheel basically in a circle even when the truck is off, how do i get to the tilt wheel area? I know remove the steering wheel....but what else do I need? It's a common issue I've seen b4, but never taken 1 apart myself.
Re: 1984 Dodge Ram Steering Wheel Issue [Re: 79volare] #2458040
02/26/18 07:51 PM
02/26/18 07:51 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
You certain it's not the shaft coupler right above gearbox causing the slop. They go bad alot on them.
Re: 1984 Dodge Ram Steering Wheel Issue [Re: 79volare] #2458137
02/26/18 10:57 PM
02/26/18 10:57 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Sounds like the bolts for the tilt mechanism came loose. Pretty common.
I'd you tube it for how to. It's not terrible but you will need a lock plate tool and puller for the pivot pins. Parts stores usually have them for not much money.
Angry white pureblood male
Re: 1984 Dodge Ram Steering Wheel Issue [Re: 79volare] #2458200
02/27/18 12:21 AM
02/27/18 12:21 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
some parts stores rent or loan tools. I know O'Reillys does.
Re: 1984 Dodge Ram Steering Wheel Issue [Re: 79volare] #2458274
02/27/18 10:34 AM
02/27/18 10:34 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Its the tilt under the wheel.The bolts come loose and the wheel moves.Did tons of them at work and also on my Ram.Its a GM column.Take the wheel off and you will see the tilt part under the piece for turnsignal /horn etc.Tighten them down.Some are a pain to get to.Been like 20 years since Ive done one but not a terrible job.Rocky
Chrysler Firepower
Re: 1984 Dodge Ram Steering Wheel Issue [Re: therocks] #2458334
02/27/18 12:57 PM
02/27/18 12:57 PM
moparx Offline
moparx  Offline
some tilt mechanisms you can get to the bolts without pulling the pins. you just have to get creative with your tool kit and tilting the wheel into different positions. the bolt heads may also be male torx fasteners. as said before, common problem. if i can get the bots out, i spray "electrical" cleaner in the holes, then use a dab of "pink" loctite on the threads.
beer
Re: 1984 Dodge Ram Steering Wheel Issue [Re: 79volare] #2458445
02/27/18 04:02 PM
02/27/18 04:02 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree I did many without pulling the pins.I always locktite them when i can get to the threads Never had any work loose after that.In the day did tons at the shop on GMs.Rocky
Chrysler Firepower
