Drum brake master cylinder studs #2453450
02/18/18 01:45 PM
02/18/18 01:45 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
Were there different dia studs used in different years? I got a new master cylinder for my 69 charger and the mounting holes are too big and the studs just spin freely. I am thinking maybe some one swapped a different year master on years ago complete with the matching studs.
Re: Drum brake master cylinder studs [Re: crowbait] #2453459
02/18/18 02:03 PM
02/18/18 02:03 PM
A727Tflite Online content
A727Tflite  Online Content
That just happened to me too. Bought a new aftermarket and the splines of the studs just barely hold them in the master.
I took the master back off and took a longer tapered punch to the back side and a couple of little whacks raised enough metal to hold the studs in place. Once I got it back on the car though I had to hold those studs while tightening the nuts.
Re: Drum brake master cylinder studs [Re: crowbait] #2453460
02/18/18 02:06 PM
02/18/18 02:06 PM
moparx Offline
moparx  Offline
how big are the holes ? you are going manual brakes, correct ? does the master cylinder have the recess in the piston ? any of these i have touched in my lifetime has been 5/16" studs, but i never really popped out studs to compare the knurl. maybe your replacement is kind of generic ? don't forget, you dumped off a master here quite a while back. we can compare it to what you got now. [and i got MORE floor . biggrin]
beer
Re: Drum brake master cylinder studs [Re: crowbait] #2453787
02/19/18 03:39 AM
02/19/18 03:39 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I'm changing the master now,when I get down to the garage I will try to get you a measurement.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Drum brake master cylinder studs [Re: hemi-itis] #2454945
02/21/18 04:00 AM
02/21/18 04:00 AM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
Dug up my old one of my 66 coronet tonite. I will measure tomorrow..Im whipped right now.
Re: Drum brake master cylinder studs [Re: crowbait] #2457483
02/25/18 08:21 PM
02/25/18 08:21 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
Ok
original off my 66 coronet manual drum car measures 0.340.
Both new parts store ones measure 0.360-0.370.What gives? I guess I am gonna have to look around for studs with larger knurl dia.
Re: Drum brake master cylinder studs [Re: crowbait] #2457594
02/25/18 11:22 PM
02/25/18 11:22 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Originally Posted By crowbait
Ok
original off my 66 coronet manual drum car measures 0.240.
Put a little quick set JB Weld on the knurls,It should hold until you get the nuts started. I have used super glue, the thicker kind,but the JB would work better.
Re: Drum brake master cylinder studs [Re: crowbait] #2458384
02/27/18 02:05 PM
02/27/18 02:05 PM
hemi-itis Offline
hemi-itis  Offline
I found the stud holes to be 5/16,the holes in the adapter for my master upgrade are 5/16.BUT,,the adapter I bought has larger holes in them so everything will be nut & bolted.
Re: Drum brake master cylinder studs [Re: hemi-itis] #2458444
02/27/18 04:01 PM
02/27/18 04:01 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
How about putting sleeves on the studs, or sleeves in the holes?
Re: Drum brake master cylinder studs [Re: John Brown] #2458792
02/28/18 12:39 PM
02/28/18 12:39 PM
moparx Offline
moparx  Offline
i even thought about using a piece of shim stock wrapped around the original stud. i looked through my stud collection, but i didn't have anything. i suggested a nut & bolt, but he didn't want to go that route. the only manual stuff i have has the studs tacked to the pedal assembly, so no help there.
beer
