Question on the Caltracs #2457106
02/25/18 01:39 AM
02/25/18 01:39 AM
CA
David Lee Offline OP
CA
I got the springs and the Caltrac 4200 Dran 2 hole profile setup.
I noticed the spring plate does not come with a shock mounting stud.
What would you recommend. This is for a 67 Barracuda with a 8 3/4 rear stock shock mounting points using Calvert shocks
Ah...so many pedestrians, so little time...
Re: Question on the Caltracs [Re: David Lee] #2457110
02/25/18 01:51 AM
02/25/18 01:51 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
I think the HELP brand sells them.
Think it's for a chevy .
That's what I used
Re: Question on the Caltracs [Re: David Lee] #2457112
02/25/18 01:54 AM
02/25/18 01:54 AM
a493demon Offline
a493demon  Offline
Re: Question on the Caltracs [Re: David Lee] #2457197
02/25/18 10:31 AM
02/25/18 10:31 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
On my 68 Barracuda the doorman shock mounts pushed the shock back a little far for my liking. I ended up just using bolts with a sleeve to fill the bushing diameter in the shock. Has worked well for 6 or 7 years.
68 Barracuda Formula S 340
Re: Question on the Caltracs [Re: David Lee] #2457239
02/25/18 12:25 PM
02/25/18 12:25 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
iagree
Re: Question on the Caltracs [Re: David Lee] #2457321
02/25/18 02:51 PM
02/25/18 02:51 PM
AndyF Offline
AndyF  Offline
I didn't like how the Calvert lower plates were designed so I made my own.
http://arengineering.com/products/shock-plate-race-style/
Re: Question on the Caltracs [Re: Bad340fish] #2457325
02/25/18 02:58 PM
02/25/18 02:58 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Same here with my 67 Barracuda, bolt with cone shaped spacers.
Re: Question on the Caltracs [Re: AndyF] #2457331
02/25/18 03:17 PM
02/25/18 03:17 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Andy - is that a tie down hook integrated to the plate?
Re: Question on the Caltracs [Re: David Lee] #2458516
02/27/18 06:32 PM
02/27/18 06:32 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
The kit comes with s set of shock bolts to bolt the shock to the plate.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: Question on the Caltracs [Re: AndyF] #2458524
02/27/18 06:46 PM
02/27/18 06:46 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Andy
What am I overlooking in yoru photo's. I do not see the bracket to mount the bar to. Is it just really short or something?
Other than that question, I REALLY like how yours is made compared to the Calverts
Old Geezer Racing
Re: Question on the Caltracs [Re: SCATPACK 1] #2458553
02/27/18 08:01 PM
02/27/18 08:01 PM
AndyF Offline
AndyF  Offline
Andy
Good question, I missed it in my first reply. This is a "u weld it" kit so you need to buy the brackets for the link bar separate. Some guys just want the shock plate with the double shear shock mount, other guys want the whole kit so they can run a link bar.
http://arengineering.com/products/caltrac-plates/
Re: Question on the Caltracs [Re: markz528] #2458554
02/27/18 08:02 PM
02/27/18 08:02 PM
AndyF Offline
AndyF  Offline
Yes, I added a loop hole in the plate for tie downs.
