Brake lines #2456589
02/24/18 11:51 AM
02/24/18 11:51 AM
nj
MoJoe Offline OP
MoJoe  Offline OP
nj
I'm looking for a few tips on brake lines...mostly removing them without breaking or damaging them....as I have already done. I also need some tips on bending and flaring them...before I do more damage.
Re: Brake lines [Re: MoJoe] #2456594
02/24/18 11:59 AM
02/24/18 11:59 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
On flaring, it is best if you remove the ridge inside the tube caused by your cutoff tool before you start the flair. Also, make sure the end of the tubing is flat and square, not tapered from the cutoff tool. A file works well for that. I also lightly lube the end of the tube before starting the flair. Good luck. All it takes is a bit of practice and you will get to be a pro at it.
Re: Brake lines [Re: MoJoe] #2456611
02/24/18 12:34 PM
02/24/18 12:34 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
Use nickel-copper brake lines to make your life easier and your lines corrosion resistant.
https://oppositelock.kinja.com/the-truth-about-copper-brake-lines-1818499200
https://www.copper.org/applications/automotive/brake-tube/brake.html
For flaring, I recommend this flaring tool from Eastwood:
https://www.eastwood.com/eastwood-on-car-flaring-tool-for-3-16-tubing.html
Here are a couple of photos of new rear axle brake lines for my '55 Plymouth.
