Kelsey/hayes 4 piston or later single piston? #245625
03/07/09 01:25 AM
03/07/09 01:25 AM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
What is a better brakeing system, 68 cuda 4 piston K/H set up or say a single piston set up from a 75 duster?
Pros and cons
Re: Kelsey/hayes 4 piston or later single piston? [Re: HotRodDave] #245626
03/07/09 01:07 PM
03/07/09 01:07 PM
The single piston setup is cheaper,less troublesome,less parts & parts are easier to come by & have BBP. When buying calipers the '76 A body calipers have 2.75" bore as opposed to 2.60" on 73-75 A bodys. gives more bias towards the front & helps counteract rear wheel lockup & better yet would be to get a pair of 11&3/4" caliper adapters & the larger rotors to go along with them & some better pads
Re: Kelsey/hayes 4 piston or later single piston? [Re: HotRodDave] #245627
03/07/09 05:27 PM
03/07/09 05:27 PM
Texas
vynn3 Offline
vynn3  Offline
Texas
LOVE my KH disks. Have them on 2 cars, both stop very well. Small bolt pattern doesn't bother me - I like Rallyes, steelies, and Coy's C-5s, 14"-20" sizes are covered. Oh, and a narrower track than late model disks, which looks better and provides better tire to fender clearance.
Re: Kelsey/hayes 4 piston or later single piston? [Re: vynn3] #245628
03/07/09 06:03 PM
03/07/09 06:03 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
It sounds as if you're doing a conversion in which case even if you find the 4 piston calipers you'll never find replacement parts.
Re: Kelsey/hayes 4 piston or later single piston? [Re: Stanton] #245629
03/07/09 07:56 PM
03/07/09 07:56 PM
Kalispell Mt.
Kalispell Mt.
I have the later discs on mine now and got a set of the KHs in a trade and was wondering if it would be worth while to put them on instead. I forgot about the SBP so I am going to sell them.
Re: Kelsey/hayes 4 piston or later single piston? [Re: Stanton] #245630
03/07/09 08:53 PM
03/07/09 08:53 PM
Texas
vynn3 Offline
vynn3  Offline
Texas
Rebuild kits, pistons, pads, lines are all available. Small parts are the same as Mustangs (and a FEW places repop parts for those). What parts are you talking about? Just because you can't pick 'em up down the street at Autozone doesn't mean you can't find 'em at all.
vm
Re: Kelsey/hayes 4 piston or later single piston? [Re: HotRodDave] #245631
03/07/09 08:58 PM
03/07/09 08:58 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
The early Mustangs used the same Kelsey disc brakes. Parts are availible. Easy rebuild!!
http://www.trophymustang.com/disc-brakes-caliper-parts-c-85_293_331.html
Re: Kelsey/hayes 4 piston or later single piston? [Re: R/T1968R/T] #245632
03/09/09 02:14 AM
03/09/09 02:14 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The K-H are a better brake, EXCEPT for the thin rotor (not legal to be turned, either).
