Kelsey/hayes 4 piston or later single piston?
#245625
03/07/09 01:25 AM
03/07/09 01:25 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
What is a better brakeing system, 68 cuda 4 piston K/H set up or say a single piston set up from a 75 duster? Pros and cons
Re: Kelsey/hayes 4 piston or later single piston?
[Re: HotRodDave]
#245626
03/07/09 01:07 PM
03/07/09 01:07 PM
RapidRobert
The single piston setup is cheaper,less troublesome,less parts & parts are easier to come by & have BBP. When buying calipers the '76 A body calipers have 2.75" bore as opposed to 2.60" on 73-75 A bodys. gives more bias towards the front & helps counteract rear wheel lockup & better yet would be to get a pair of 11&3/4" caliper adapters & the larger rotors to go along with them & some better pads
[Re: Stanton]
#245629
03/07/09 07:56 PM
03/07/09 07:56 PM
HotRodDave
Kalispell Mt.
I have the later discs on mine now and got a set of the KHs in a trade and was wondering if it would be worth while to put them on instead. I forgot about the SBP so I am going to sell them.
[Re: Stanton]
#245630
03/07/09 08:53 PM
03/07/09 08:53 PM
Posts: 411 Texas
vynn3
Texas
It sounds as if you're doing a conversion in which case even if you find the 4 piston calipers you'll never find replacement parts.
Rebuild kits, pistons, pads, lines are all available. Small parts are the same as Mustangs (and a FEW places repop parts for those). What parts are you talking about? Just because you can't pick 'em up down the street at Autozone doesn't mean you can't find 'em at all.
vm
