Slant 6 Torsion Bars 622 / 623 Install Sides
#2456018
02/23/18 09:33 AM
02/23/18 09:33 AM
Posts: 192 Gravataí, RS, Brazil
360tripleblack77
Hi folks, yesterday I received my slant 6 622 / 623 torsion bars but I've some doubts about sides of installation. Which one is Driver and Passenger side.
'77 Brazilian Dodge Charger R/T - Street Car Footbrake, Pump Gas, SB Mopar 360" N/A 3300lbs, Leaf Spring + Assassin Bars Best 1/8 mile ET 1.50 60' / 4.31 330' / 6.73@102.54mph
Re: Slant 6 Torsion Bars 622 / 623 Install Sides
[Re: 360tripleblack77]
#2456020
02/23/18 09:48 AM
02/23/18 09:48 AM
Guitar Jones
With Mopar part numbers the right is the even last number and left is the odd number. There are a few exceptions though so I don't know about those bars specifically.
[Re: Guitar Jones]
#2456031
02/23/18 10:41 AM
02/23/18 10:41 AM
360tripleblack77
Thanks GJ.
I found this information in another forum:
There are numbers stamped into the end of the torsion bar which will identify what diameter bar it is, but you to have the bar removed to see it. There's usually some paint splotch too...different diameters have different colours.
A-body Slant 6 .83" - yellow - 622/623(R/L early) 880/889(late)
A-body 2-bbl V8 .85" - Olive - 624/625(R/L early) 890/891 late)
A-body 4-bbl V8 .87" - Blue - 626/627(R/L early) 892/893(late)
My bars has the yellow color spots also...
