Re: Leaky china rail
[Re: 1mean340]
#2455671
02/22/18 04:01 PM
02/22/18 04:01 PM
Posts: 43,126 Bend,OR USA
Cab_Burge
Go to your local good auto parts store and see if they have any RTV that says "Adhesive sealer or Adhesive silicone on the label, if they do buy it and use a small thin bladed screw drivers to pack that silicone in the leaking area after cleaning it thoroughly with either laquer thinner or brake cleaner solution Make sure it is clean and dry before using the sealer
[Re: 1mean340]
#2455674
02/22/18 04:05 PM
02/22/18 04:05 PM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I always test fit my intake on my block and measure how big of a bead of silicon I need. I have Permatex black silicon in the big tubes on my caucking gun so then I can lay down the needed bead. I also take a black magic marker and trace a line around the intake during my test fitting so I know exactly where to lay the bead.
[Re: 1mean340]
#2455739
02/22/18 06:29 PM
02/22/18 06:29 PM
Posts: 11,530 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Cab's fix should be fine for a temporary fix. I haven't used a gasket on intake end rails for decades. Next time the intake comes off, put the side gaskets on, sit the clean intake on it and look at the gap to get an idea of what is needed. The silicon bead needs to be a bit thicker than the gap to get a squish effect. Use something with some body to it like the gray Permatex. If the gap is wide, multiple passes can be used to build height. Blend the ends up into the gaskets. I usually allow it to sit for a few minutes, before dropping the intake on it, to allow the silicone to skin and tighten up some so it doesn't just ooze out when compressed. Clean everything with lacquer thinner before assembly.
[Re: 1mean340]
#2455761
02/22/18 07:09 PM
02/22/18 07:09 PM
Posts: 103 Washington
weedburner
Washington
A shop vac plays heavily into my leak sealing methods I use a shop vac and stethoscope to locate the leak. I use a shop vac to draw cleaner into the leak. I use a shop vac to help dry out the leak. I use a shop vac to draw some sealer into the freshly cleaned leak. After removing the shop vac, smooth the outside without vacuum applied to seal any holes drawn by the vacuum. Let it cure overnite. To make the leak easier to hear, you can cover the shop vac with a couple heavy blankets to reduce it's noise. Another solution is to buy more hose and place the shop vac outside. Grant
[Re: 1mean340]
#2455921
02/23/18 12:58 AM
02/23/18 12:58 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I agree the shop vac method is great, I have seen it used for all kinds of stuff, even changing drain plug gaskets while the engine is full of oil.
68 Barracuda Formula S 340
[Re: 1mean340]
#2456205
02/23/18 03:59 PM
02/23/18 03:59 PM
Posts: 370 Suffolk County, New York
1mean340
Thanks guys! it looks like it's seeping across the whole front of the china rail then dripping badly out from the corner down the head. I ordered new gaskets from Flatout with 2nd day air but I think I am going to give the shop vac idea in conjunction with what Cab said first. Might as well give it a shot, fingers crossed as I'll need all the time I can get this weekend to adjust the valves and continue trying to tune this FITECH 1200 on E85 to make it at least somewhat drivable.
[Re: Cab_Burge]
#2456401
02/23/18 11:50 PM
02/23/18 11:50 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I will probably get push back on this.. but the right stuff sucks.. install a healthy beat let it sit for a few days and cut it open with a razor blade it's full of hollow Pockets from the aerosol that used to push it out of the can.. I think it should only be used in a pinch because it dries very quickly.. however I have had numerous issues using the right stuff.. especially when trying to use a vacuum pump.. my Motors never leak oil only air.. I would tape everything up and use a heavy grade window silicone.. you can get it at your local hardware store.. and you apply it with a caulking gun.
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
