Re: Any Carter AVS Gurus in here??
[Re: SSDart]
#2455418
02/22/18 02:12 AM
02/22/18 02:12 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Find someone that runs NSS in a Mopar. They’ll know their way around an AFB. There’s a few guys that frequent this board that Check that box. Doug (DVW) comes to mind.
[Re: SSDart]
#2455426
02/22/18 02:41 AM
02/22/18 02:41 AM
Posts: 43,127 Bend,OR USA
Cab_Burge
[Re: SSDart]
#2455428
02/22/18 02:41 AM
02/22/18 02:41 AM
Posts: 204 Indiana
nssracer1
Indiana
Dean Oliver in Stutgard,AR did the one on my Stocker Cuda. He is really good.
[Re: SSDart]
#2455495
02/22/18 08:19 AM
02/22/18 08:19 AM
Posts: 9,825 MI, usa
dvw
MI, usa
[Re: SSDart]
#2455566
02/22/18 01:12 PM
02/22/18 01:12 PM
RapidRobert
All OE AVS's are lean from the discombobulated emission requirements of that era (68-71) when Ma & the rest of em were trying to keep up with the strict federally mandated emission stds. convert the tall pri jets/3 step rods to eddy performer short pri jets/2 step rods. a few thou richer on cruise/power might be a good start. AVS strip kits are as rare as can be. EDIT An AFB is a far better carb to work with (if you have a choice).
[Re: RapidRobert]
#2455574
02/22/18 01:25 PM
02/22/18 01:25 PM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
All OE AVS's are lean from the discombobulated emission requirements of that era (68-71) when Ma & the rest of em were trying to keep up with the strict federally mandated emission stds. convert the tall pri jets/3 step rods to eddy performer short pri jets/2 step rods. a few thou richer on cruise/power might be a good start. AVS strip kits are as rare as can be. EDIT An AFB is a far better carb to work with (if you have a choice). To the op, thanks for posting this thread. I like Rapid Robert's tip & it may be the solution to my bro's 517 Hemi's lean backfire problem. He's got 2 650 Eddy Thunders (AVS) & after a few yrs, its developed a carb backfire on WOT from crusing speed. Their accelerator pump linkage is already on the top hole & springs, jets & rods were replaced on install. SO maybe, if we can find a qualified tech in Vegas (no old school gurus here), maybe this is the fix. May send them off to Competition Carbs (Oliver), to have this done. Thanks again.
[Re: Triggerfish]
#2455586
02/22/18 01:48 PM
02/22/18 01:48 PM
RapidRobert
Triggerfish, the messed up calibrations were in the OE (68-71) AVS's only. the later AVS thunders would not have that issue. now you can get the OE AVS's to run like a scalded dog if you put some work into em but for the nth degree of performance there are much better carb choices. but on the early AVS's, He may already have em/they may be required for class rules/he might not want to buy new carbs.
[Re: RapidRobert]
#2455593
02/22/18 01:56 PM
02/22/18 01:56 PM
Triggerfish
Blairsden, CA
Triggerfish, the messed up calibrations were in the OE (68-71) AVS's only. the later AVS thunders would not have that issue. now you can get the OE AVS's to run like a scalded dog if you put some work into em but for the nth degree of performance there are much better carb choices. but on the early AVS's, He may already have em/they may be required for class rules/he might not want to buy new carbs. Thanks Robert & not trying to hijack the op's thread, but maybe the carbs just have some dirt in some of the circuits. OR, maybe its the huge content of ethanol & other crap in the winter blend Vegas pump 91. Think we'll try 5 gal of race gas & see if it cures the issues. As for the op's question, I spoke to Oliver (Competition Carbs) on the phone a few yrs back & he was super helpful.
[Re: Triggerfish]
#2455606
02/22/18 02:22 PM
02/22/18 02:22 PM
RapidRobert
We're here to help & be helped by as many people as possible. I look at it as the random acts of kindness movement that is catching on to some extent (& sorely needed). It makes me feel grateful that non ethanol has always been available here (& we're the #3 corn producing state in the country). I remember way back in the early 80's that people were complaining that their engines were dying at stoplights & I told em to use non ethanol & problem was solved. Post what it ends up being
[Re: SSDart]
#2455648
02/22/18 03:19 PM
02/22/18 03:19 PM
Cab_Burge
[Re: SSDart]
#2455688
02/22/18 04:28 PM
02/22/18 04:28 PM
Posts: 168 Moparts
SSDart
Moparts
It has two .110 seats now. I think I will be alright seat wise.... Q-jets only have one at .135.
[Re: Triggerfish]
#2455972
02/23/18 02:45 AM
02/23/18 02:45 AM
Posts: 10,201 Someplace you aren't
SomeCarGuy
All OE AVS's are lean from the discombobulated emission requirements of that era (68-71) when Ma & the rest of em were trying to keep up with the strict federally mandated emission stds. convert the tall pri jets/3 step rods to eddy performer short pri jets/2 step rods. a few thou richer on cruise/power might be a good start. AVS strip kits are as rare as can be. EDIT An AFB is a far better carb to work with (if you have a choice). To the op, thanks for posting this thread. I like Rapid Robert's tip & it may be the solution to my bro's 517 Hemi's lean backfire problem. He's got 2 650 Eddy Thunders (AVS) & after a few yrs, its developed a carb backfire on WOT from crusing speed. Their accelerator pump linkage is already on the top hole & springs, jets & rods were replaced on install. SO maybe, if we can find a qualified tech in Vegas (no old school gurus here), maybe this is the fix. May send them off to Competition Carbs (Oliver), to have this done. Thanks again. Did those carbs always do that? Sounds like no. What changed?
I want my fair share
[Re: SomeCarGuy]
#2455981
02/23/18 03:25 AM
02/23/18 03:25 AM
Triggerfish
Blairsden, CA
All OE AVS's are lean from the discombobulated emission requirements of that era (68-71) when Ma & the rest of em were trying to keep up with the strict federally mandated emission stds. convert the tall pri jets/3 step rods to eddy performer short pri jets/2 step rods. a few thou richer on cruise/power might be a good start. AVS strip kits are as rare as can be. EDIT An AFB is a far better carb to work with (if you have a choice). To the op, thanks for posting this thread. I like Rapid Robert's tip & it may be the solution to my bro's 517 Hemi's lean backfire problem. He's got 2 650 Eddy Thunders (AVS) & after a few yrs, its developed a carb backfire on WOT from crusing speed. Their accelerator pump linkage is already on the top hole & springs, jets & rods were replaced on install. SO maybe, if we can find a qualified tech in Vegas (no old school gurus here), maybe this is the fix. May send them off to Competition Carbs (Oliver), to have this done. Thanks again. Did those carbs always do that? Sounds like no. What changed? Nothing except it sat for almost 3 weeks before being driven, so maybe its varnish or contaminants causing it. But it didn't backfire today when he drove it. He's got 2 elec fuel pump systems he can select. One's an Aermotive in tank system & the other a Holley Gerotor pump. 1/2" feed & return lines. No chokes on the carbs.
[Re: Triggerfish]
#2456107
02/23/18 01:41 PM
02/23/18 01:41 PM
Posts: 168 Moparts
SSDart
Moparts
All OE AVS's are lean from the discombobulated emission requirements of that era (68-71) when Ma & the rest of em were trying to keep up with the strict federally mandated emission stds. convert the tall pri jets/3 step rods to eddy performer short pri jets/2 step rods. a few thou richer on cruise/power might be a good start. AVS strip kits are as rare as can be. EDIT An AFB is a far better carb to work with (if you have a choice). To the op, thanks for posting this thread. I like Rapid Robert's tip & it may be the solution to my bro's 517 Hemi's lean backfire problem. He's got 2 650 Eddy Thunders (AVS) & after a few yrs, its developed a carb backfire on WOT from crusing speed. Their accelerator pump linkage is already on the top hole & springs, jets & rods were replaced on install. SO maybe, if we can find a qualified tech in Vegas (no old school gurus here), maybe this is the fix. May send them off to Competition Carbs (Oliver), to have this done. Thanks again. Did those carbs always do that? Sounds like no. What changed? Nothing except it sat for almost 3 weeks before being driven, so maybe its varnish or contaminants causing it. But it didn't backfire today when he drove it. He's got 2 elec fuel pump systems he can select. One's an Aermotive in tank system & the other a Holley Gerotor pump. 1/2" feed & return lines. No chokes on the carbs. Spraying WD40 around the air bleeds can do wonders. Good idea to do once in a while.
