RTE Tachometer Calibrator/Exerciser #2455286
02/21/18 09:25 PM
02/21/18 09:25 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
Does any one have the instructions that go with this device?
I have some how lost the ones that I had and have come up with nothing searching the internet.
Re: RTE Tachometer Calibrator/Exerciser [Re: rarefish] #2455309
02/21/18 10:20 PM
02/21/18 10:20 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: RTE Tachometer Calibrator/Exerciser [Re: rarefish] #2455331
02/21/18 10:53 PM
02/21/18 10:53 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
I ran up and down the links on the site, but unfortunately found nothing on the Calibrator.
It's a neat little tool that I believe is no longer made. I'm sure there is others out there that have one.
Re: RTE Tachometer Calibrator/Exerciser [Re: rarefish] #2455350
02/21/18 11:25 PM
02/21/18 11:25 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Only thing I could find that might help?... http://rt-eng.com/rte/images/c/ce/M5tachboard_manual.pdf
Re: RTE Tachometer Calibrator/Exerciser [Re: rarefish] #2455376
02/22/18 12:12 AM
02/22/18 12:12 AM
WA
tman Offline
tman  Offline
WA
Did you try contacting them? They have an ebay store in that name. Might be able to ask them directly.
Re: RTE Tachometer Calibrator/Exerciser [Re: rarefish] #2455458
02/22/18 03:41 AM
02/22/18 03:41 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
You can also send it in and let them install, and cal at the same time.
Re: RTE Tachometer Calibrator/Exerciser [Re: 71birdJ68] #2455591
02/22/18 01:53 PM
02/22/18 01:53 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
What's in my picture is the "Calibrator/Exerciser" that they use to manufacture and sell. You are thinking of the tach replacement board that they still sell.
The device I have is used to bench calibrate and exercise the needle bearing before reinstalling the tach.
Re: RTE Tachometer Calibrator/Exerciser [Re: rarefish] #2458539
02/27/18 07:22 PM
02/27/18 07:22 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
See attachments
Re: RTE Tachometer Calibrator/Exerciser [Re: Sixpak] #2458620
02/27/18 11:21 PM
02/27/18 11:21 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
Thanks, That's the one.
Re: RTE Tachometer Calibrator/Exerciser [Re: rarefish] #2458680
02/28/18 01:33 AM
02/28/18 01:33 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Can you get some good pics of both sides of the circuit board? I'd like to see what is involved in making one.
Re: RTE Tachometer Calibrator/Exerciser [Re: Jim_Lusk] #2458865
02/28/18 02:13 PM
02/28/18 02:13 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
Here is a couple of pics...
Re: RTE Tachometer Calibrator/Exerciser [Re: rarefish] #2459100
02/28/18 10:20 PM
02/28/18 10:20 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Thanks. Not very helpful, though. Surface mount components are hard to identify. I'll look around to see if I can find a schematic.
