Re: my springs are sagging [Re: mickm] #2455036
02/21/18 12:36 PM
02/21/18 12:36 PM
MarkZ Online boogie
Worthy
MarkZ  Online Boogie
Worthy
Replaced the springs on my car with a set of five leaf spring (stock are four) from JohnR Spring here in Michigan about seven years ago now. Back end hasn't sagged at all since installing them. Think I paid $250 for them and that included new rubber bushings.
Re: my springs are sagging [Re: MarkZ] #2455127
02/21/18 03:55 PM
02/21/18 03:55 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Now right there is a helluva good tip.^^
Mick, what area are you in in CA? I can probably find a good truck spring shop out your way that can build a GOOD set for you! I've got 3 reps out there that have been in the truck parts industry for many years - they know all the good shops.
Re: my springs are sagging [Re: mickm] #2455155
02/21/18 04:41 PM
02/21/18 04:41 PM
My hovercraft is full of eels
DaveKanofsky Offline
Put ESPO in my Daytona 15 years ago and still doing great.
I've put ESPO in everything ever since the first set of EATON ones sagged early on.
MOPARS ONLY!
'69 Daytona, '16 Plum Crazy Challenger, '12 Durango, '01 Sebring conv't
Chaplain, Racers For Christ (http://teamrfc.org/)
John 3:17
Re: my springs are sagging [Re: Sunroofcuda] #2455166
02/21/18 05:10 PM
02/21/18 05:10 PM
California
mickm Offline OP
mickm  Offline OP
California
I'm in the SF Bay Area. Bett's is the trucking spring company I've been talking to.
Re: my springs are sagging [Re: mickm] #2455230
02/21/18 07:34 PM
02/21/18 07:34 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
I've used ESPO several times over the years and no complaints from me.
Re: my springs are sagging [Re: mickm] #2455393
02/22/18 01:14 AM
02/22/18 01:14 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
I e-mailed my rep - stay tuned.............
Re: my springs are sagging [Re: RV2] #2456933
02/24/18 08:55 PM
02/24/18 08:55 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
I have ESPO's on my Duster...no problems with them yet... twocents
Plymouth Makes It!
Re: my springs are sagging [Re: mickm] #2457863
02/26/18 02:12 PM
02/26/18 02:12 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Previous owner did the springs of my car. I've owned it 15 years, no sag yet. However the back end is quite high so it could sag a little and I would never know!
I would agree with 4406bbl's comment on add-a-leaf length. I did them on my jeep and it gave the lift I wanted but a short helper leaf will induce an s-bend in the main leaf if it's already weak.
Originally Posted By Grizzly
Mick, that spring shop fed you a line.
They effed them springs up for you when they re-arched them.
"Spring steel" is beyond my understanding of Metalurgy, but it's a special metal treatment and tampering with it either by cold bending or hot bending ruins them.
IMO there's some truth to it. Leaf springs are made out of a variety of different grades of steel, each with its own heat treating and tempering requirements. A spring shop has no way of knowing what they're working with in terms of both the grade of steel and how close the chemical composition comes to actually meeting the specification for the grade of steel it is supposed to be according to the manufacturer.
Re: my springs are sagging [Re: mickm] #2458027
02/26/18 07:38 PM
02/26/18 07:38 PM
A727Tflite Offline
A727Tflite  Offline
If I recall correctly - valve springs, coil springs, leaf springs - are all qualified by spring rate.
There may be durability differences between the various metals used.
I recall also that back in the day when Super Stock springs were the go to spring - they were "bulldozed" when new. That means they were over compressed after they were built. This resulted in them taking the proper set (chamber). Sort of reverse "re-arcing".
I'm guessing since these are "Hecho en Mexico" - that's not being done now. So they take a set on your car.
I think the good ones used to be made in Canada.
Back to Kuality Kontrol at Ma Mopar' Performance Parts Group being out to lunch.
EDIT :
I typed in bulldozing springs in Google and it took me to Suspension Specialists - Tech Talk.
So I guess my memory isn't too bad after all.
Re: my springs are sagging [Re: A727Tflite] #2458144
02/26/18 11:06 PM
02/26/18 11:06 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Bingo...
Re: my springs are sagging [Re: RSNOMO] #2458329
02/27/18 12:52 PM
02/27/18 12:52 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
Bingo...
but the OP bought some nice, high quality Eaton springs and they are the ones sagging.
Re: my springs are sagging [Re: mickm] #2458741
02/28/18 10:03 AM
02/28/18 10:03 AM
NC, USA
davenc Offline
davenc  Offline
NC, USA
When adding an extra leaf, do you need to get a longer center bolt for the spring pack? Where do you find something like this?
Re: my springs are sagging [Re: mickm] #2458850
02/28/18 01:58 PM
02/28/18 01:58 PM
Manitoba, Canada
Manitoba, Canada
Yes you will need a longer bolt. Last ones I did the bolt came with the helper springs. Search summit for leaf spring tie bolt.
Re: my springs are sagging [Re: krautrock] #2458897
02/28/18 02:47 PM
02/28/18 02:47 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Bingo...
What does that have to do with the MP reference in the post???
What type of steel Eaton spring uses is YTBD...
I believe 'mickm' is being steered in the right direction...
Re: my springs are sagging [Re: mickm] #2459005
02/28/18 06:30 PM
02/28/18 06:30 PM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
I have a set of ESPO and they've kept me happy with their springs. I will use a set on my 69 Bee also!
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
