Question on bullet style mufflers
#2455081
02/21/18 02:19 PM
02/21/18 02:19 PM
Posts: 11,729 Portage,michigan
B3422W5
Portage,michigan
Gonna buy a set of bullet style mufflers to quiet the car down a little from open headers, for some street use. Have had dynomax bullets in the past and liked them. I see Kooks also makes this style muffler. Any opinions on what night be the best to use. Looking for something to knock down the noise some, but extremely free from restriction as well. Will probably race the car with whatever i buy kept on the car
Re: Question on bullet style mufflers
[Re: B3422W5]
#2455085
02/21/18 02:24 PM
02/21/18 02:24 PM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
Big fan of the Dynomax Bullets here. Have a pair of 4" bullets I use on the car at the track. Way quieter than open headers, but runs the same with or without them. Slows down w/ every other exhaust I've tried.
[Re: B3422W5]
#2455101
02/21/18 02:47 PM
02/21/18 02:47 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
I've used both, Dynomax Bullets, the Race Bullets and the Mini Bullets. I like the Minis, a lot lighter and not that much louder.
I have a new pair of the minis in 3.5" inlet outlet I'm not going to use.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: B3422W5]
#2455102
02/21/18 02:53 PM
02/21/18 02:53 PM
Posts: 4,457 Washington
madscientist
Washington
I used Custom Craft. Still do. I think that's the name.
[Re: B3422W5]
#2455104
02/21/18 02:56 PM
02/21/18 02:56 PM
madscientist
Washington
Dang it...I use Car Chemisrty mufflers. Have since about 1992.
[Re: topside]
#2455150
02/21/18 04:29 PM
02/21/18 04:29 PM
Posts: 4,585 Motor City
6PKRTSE
Motor City
We have the "muffler required" on our local Drag Radial class. I took a race Bullet muffler & cut it in half & made two out of one under my car. Rule just says you have to have them. Does not say how small they can be.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: B3422W5]
#2455176
02/21/18 05:31 PM
02/21/18 05:31 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
I put a set of the old crimp style Magnaflow 14x7x3.0 inch side inlet and center outlet muffs at the rear bumper with 3.0 inch pipes all the way through the system from the Hooker fenderwell headers on my old pump gas Duster, that car picked up .02 ET and .2 MPH in the 1/8 mile only with them off. ![shock shock](/ubbthreads/images/graemlins/custom/shock.gif) No since in removing them really They where okay as far as in car hearing at part throttle, WOT got a lot louder On another bracket car a set of 3.5 inch Bullets off of the A body fenderwell Hooker headers slow that car down .1 ET and 1.2 MPH in the 1/4 mile
[Re: B3422W5]
#2455368
02/21/18 11:59 PM
02/21/18 11:59 PM
Posts: 1,107 Massillon, Ohio
cudatom
Massillon, Ohio
Have Dynamax on my wagon. They are pretty quiet at idle and light exceleration. But if I put my foot in it they really are no quieter than open headers.
Ok
[Re: Cab_Burge]
#2455372
02/22/18 12:07 AM
02/22/18 12:07 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I built a 3.5" x-pipe system to replace my TTI full 3" system. I drive 45 min to the track and don't want to deal with pulling the exhaust in the pits. The new system is LOUD but sounds better than open headers. The x-pipe picked up 2mph and .3-.4 at the stripe in my junk
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: OUTLAWD]
#2455378
02/22/18 12:22 AM
02/22/18 12:22 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I blew my dynamic mufflers apart in about one year. I was recommended a set of Pypes and they are going on three years. I’m still cleaning fiberglass from the bottom of my Duster
[Re: 62SAVOY]
#2455523
02/22/18 11:20 AM
02/22/18 11:20 AM
an8sec70cuda
Have a set of those on the Camaro. It has a 14.5:1 436" sb chevy in it that has a nice cackle to it...those things took the edge off the idle to where it doesn't hurt your ears as bad. It did quieten it somewhat, but not a lot. They did not slow it down at all though.
