383 A-body Trans Dip Stick
#2454319
02/20/18 12:42 AM
02/20/18 12:42 AM
Posts: 1,331 Clinton, NJ
njmopar
Clinton, NJ
Re: 383 A-body Trans Dip Stick
[Re: njmopar]
#2454510
02/20/18 01:02 PM
02/20/18 01:02 PM
Posts: 16,133 Mesa, Arizona
dart4forte
Mesa, Arizona
Looks to be correct. Ill go measure mine later and let you know. What year is your GTS?
Abe Lincoln
[Re: ph23vo]
#2455396
02/22/18 01:25 AM
02/22/18 01:25 AM
njmopar
Clinton, NJ
here's mine 68 383-S RAG all #'s.. A fellow ragtop a-body. More room there then I would imagine and to the eye appears I am good. For sure remove the stick and tape some padding around the tube for insurance. Off topic, seeing your engine bay reminds me I am missing the heater hose holder above the alternator. What build date is your car and is that the original air cleaner? Mine was missing and since I have an early October build, always wondered which style I would have. That is the larger 67 style, right?. The one I have is from a donor car being parted out that was later in October and it was the smaller style used in 68.
[Re: njmopar]
#2457843
02/26/18 01:27 PM
02/26/18 01:27 PM
dart4forte
Mesa, Arizona
Its a GTS convertible. White, black top and interior and red longitudinal stripe.
After engine install this weekend, the tube never hit, but it was way too close for my liking to the firewall at the point where the tube curves. I did a little tweaking forward and gave it what I think should be enough room. Ive had the motor in and out several times. Never had a problem. Of course it may of made a differance using a lift. Might want to consider slicing off those tbs on the valve cover gasket. You’ll get leaks if you dont. Just replaced the gasket on mine.
Abe Lincoln
[Re: dart4forte]
#2458223
02/27/18 01:40 AM
02/27/18 01:40 AM
njmopar
Clinton, NJ
What is the reason behind the tabs causing leaks?
[Re: njmopar]
#2458278
02/27/18 10:45 AM
02/27/18 10:45 AM
dart4forte
Mesa, Arizona
What is the reason behind the tabs causing leaks? Heat from the exhaust manifold. Happens with the cork, not sure about the neoprene.
Abe Lincoln
