my springs are sagging
#2454130
02/19/18 09:02 PM
02/19/18 09:02 PM
Posts: 4,179 California
mickm
California
I have 2 year old stock hemi rear springs that I got from Eaton. They left the car about 1" short of where I wanted the car to sit, so on their recommendation I took them to a local truck place and had them re-arched.
In the last 2-4 months, they have sagged close to 1.5". I had the front of the car up on jack stands for the past 2 months dealing with the k frame. I didn't expect to have it up that long, maybe I should have raised the rear as well.
Regardless, I'm stuck with some pretty damn expensive springs that are now next to useless. Eaton has more or less said that a) 1 year warranty, b) re-arching voids the warranty.
Sandy suggested simply adding a leaf or two to each side. Does anyone sell individual leaves? And what about used springs? I suppose adding anything will help, but does it make sense to add some used leaves?
Re: my springs are sagging
[Re: mickm]
#2454140
02/19/18 09:14 PM
02/19/18 09:14 PM
Posts: 15,348 Omaha Ne
TJP
Omaha Ne
[Re: mickm]
#2454157
02/19/18 10:03 PM
02/19/18 10:03 PM
Posts: 12,071 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have dealt with this same situation; wanting to maintain a particular rear height. After trying several things that cost a good bit of money and aggravation, what finally worked for me was to buy some Hellwig leaf helper springs. I mounted them on the rear segments above the springs. You cannot even tell that they are there. And I can set the rear height right where I want it and can easily change it if/when I want or need.
Master, again and still
[Re: mickm]
#2454166
02/19/18 10:13 PM
02/19/18 10:13 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
[Re: mickm]
#2454243
02/19/18 11:24 PM
02/19/18 11:24 PM
RapidRobert
Sandy suggested simply adding a leaf or two to each side. Does anyone sell individual leaves? And what about used springs? I suppose adding anything will help, but does it make sense to add some used leaves? I added a full used leaf to restore some height. As far as adding a half leaf in front or rear of the pin or a full leaf for a specific app (drags/street) that ain't my area.
[Re: Twostick]
#2454333
02/20/18 01:04 AM
02/20/18 01:04 AM
mickm
California
I have a set of Eaton springs on my New Yorker. Same experience except I didn't have to wait. Humped over backwards right off the jack, just like the 40 year old originals.
Kevin the mopar springs I bought from the dealership lasted 4-5 years. I'm thinking of just getting another set and resigning myself to 4-5 years per set...
[Re: mickm]
#2454403
02/20/18 03:38 AM
02/20/18 03:38 AM
Posts: 1,653 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Adding an extra leaf each side worked for me. The extra is a bit longer than the 2nd leaf.
[Re: a12rag]
#2454588
02/20/18 03:27 PM
02/20/18 03:27 PM
mickm
California
I bought the Mopar SS Springs for the 70 Sport Satellite when I redid the car. Within 1 year, they sagged to the point they were arched in opposite direction . . . took the original in to local shop and had them re-arched and extra leaf added - perfect height. That was 4-5 years ago now, have not sagged any . . . local shop should know what they are doing and work with you . . . Didn't think of that. I'll call the shop that re arched them and see what they say.
[Re: mickm]
#2454651
02/20/18 05:03 PM
02/20/18 05:03 PM
RapidRobert
if you go that route you can clamp the spring with large C clamps on either side aways away from the center bolt then remove the nut. I like to crack the nut with a nut cracker so as to avoid snapping the bolt if road debris has messed up the threads on the bolt below the nut to where it dont wanna come off easily. this would save you some labor & likely they will just need the main leaf(s) to rearch them but call em & ask.
[Re: mickm]
#2454834
02/20/18 11:15 PM
02/20/18 11:15 PM
mickm
California
Interesting. I had a long talk with the guy who arched the springs for me, and trying to be polite, what he said is the steel is crap. If after 2 years they have sagged not only the inch they were arched but beyond that, that is bad steel.
He also said the steel coming from Mexico currently is good stuff. India steel is bad.
I think I can attest somewhat to that, as my mopar springs that I bought years ago lasted a good 5 years or more before they started to sag. These [censored] expensive springs from Eaton didn't last 2.
He said he can put a leaf in each side that will raise it back that inch and a half, the only issue is, are they done sagging? If not, even with a good leaf in there, they will sag more.
I think I'll try and wait a bit, drive it some more, and see what it does. I'm planning on driving it to Spring Fling with some friends, but it will be bad news with 3 of us and gear in there on springs that are now 1 1/2" sagged. So I'll have to do it before April.
[Re: mickm]
#2454956
02/21/18 04:31 AM
02/21/18 04:31 AM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
Mick, that spring shop fed you a line.
They effed them springs up for you when they re-arched them.
"Spring steel" is beyond my understanding of Metalurgy, but it's a special metal treatment and tampering with it either by cold bending or hot bending ruins them.
Cheapest solution is to get a couple of off-shelf leafs with more arch than what you have now and add them to your spring pack. Hope for the best that your car will sit level on both sides and you get the height you want.
Mo' Farts
Moderated by "tbagger".
[Re: Kern Dog]
#2455011
02/21/18 11:32 AM
02/21/18 11:32 AM
Posts: 3,378 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
I once played with springs in a 73 Duster... This is what happens when the second leaf is too short! Aw, you're fine! You got 2 more holes left in those shackles to use!
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
