my springs are sagging #2454130
02/19/18 09:02 PM
02/19/18 09:02 PM
California
mickm Offline OP
mickm  Offline OP
California
I have 2 year old stock hemi rear springs that I got from Eaton. They left the car about 1" short of where I wanted the car to sit, so on their recommendation I took them to a local truck place and had them re-arched.
In the last 2-4 months, they have sagged close to 1.5". I had the front of the car up on jack stands for the past 2 months dealing with the k frame. I didn't expect to have it up that long, maybe I should have raised the rear as well.
Regardless, I'm stuck with some pretty damn expensive springs that are now next to useless. Eaton has more or less said that a) 1 year warranty, b) re-arching voids the warranty.
Sandy suggested simply adding a leaf or two to each side. Does anyone sell individual leaves? And what about used springs? I suppose adding anything will help, but does it make sense to add some used leaves?
Re: my springs are sagging [Re: mickm] #2454140
02/19/18 09:14 PM
02/19/18 09:14 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: my springs are sagging [Re: mickm] #2454149
02/19/18 09:34 PM
02/19/18 09:34 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The stock springs in my 1970 Coronet had sagged.
A pal had given me a near-mint take off set from a 1971 Challenger, so I took both sets apart.
I took the top leaf (under the main leaf) from the Challenger set & added those to the Coronet set, one on each side. They were the same thickness & length.
That got the car back to where it looked 'right' again.
Ever since then, I save old leaf spring sets, just in case.......
Re: my springs are sagging [Re: mickm] #2454157
02/19/18 10:03 PM
02/19/18 10:03 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I have dealt with this same situation; wanting to maintain a particular rear height. After trying several things that cost a good bit of money and aggravation, what finally worked for me was to buy some Hellwig leaf helper springs.
I mounted them on the rear segments above the springs. You cannot even tell that they are there. And I can set the rear height right where I want it and can easily change it if/when I want or need.
twocents
Master, again and still
Re: my springs are sagging [Re: DaveRS23] #2454162
02/19/18 10:07 PM
02/19/18 10:07 PM
IN
ahy Offline
ahy  Offline
IN
I had a full leaf added at a local spring shop - $100 for the pair. Rule of thumb this raises it an inch and also increases spring rate. In my situation I needed the higher rate so I was happy all around.
Re: my springs are sagging [Re: mickm] #2454166
02/19/18 10:13 PM
02/19/18 10:13 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
A PM...
Re: my springs are sagging [Re: mickm] #2454243
02/19/18 11:24 PM
02/19/18 11:24 PM
I added a full used leaf to restore some height. As far as adding a half leaf in front or rear of the pin or a full leaf for a specific app (drags/street) that ain't my area.
Re: my springs are sagging [Re: mickm] #2454298
02/20/18 12:14 AM
02/20/18 12:14 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I have a set of Eaton springs on my New Yorker. Same experience except I didn't have to wait. Humped over backwards right off the jack, just like the 40 year old originals.
Kevin
Re: my springs are sagging [Re: Twostick] #2454333
02/20/18 01:04 AM
02/20/18 01:04 AM
California
mickm Offline OP
mickm  Offline OP
California
Kevin
the mopar springs I bought from the dealership lasted 4-5 years. I'm thinking of just getting another set and resigning myself to 4-5 years per set...
Re: my springs are sagging [Re: mickm] #2454403
02/20/18 03:38 AM
02/20/18 03:38 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Adding an extra leaf each side worked for me. The extra is a bit longer than the 2nd leaf.
Re: my springs are sagging [Re: mickm] #2454440
02/20/18 09:45 AM
02/20/18 09:45 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
When you pay what Eaton charges, you shouldn't have to do anything but install them. I could have added a leaf to my old ones for a lot less $$$.
Kevin
Re: my springs are sagging [Re: mickm] #2454491
02/20/18 12:36 PM
02/20/18 12:36 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I bought the Mopar SS Springs for the 70 Sport Satellite when I redid the car. Within 1 year, they sagged to the point they were arched in opposite direction . . . took the original in to local shop and had them re-arched and extra leaf added - perfect height. That was 4-5 years ago now, have not sagged any . . . local shop should know what they are doing and work with you . . .
Re: my springs are sagging [Re: a12rag] #2454588
02/20/18 03:27 PM
02/20/18 03:27 PM
California
mickm Offline OP
mickm  Offline OP
California
Didn't think of that. I'll call the shop that re arched them and see what they say.
Re: my springs are sagging [Re: mickm] #2454651
02/20/18 05:03 PM
02/20/18 05:03 PM
if you go that route you can clamp the spring with large C clamps on either side aways away from the center bolt then remove the nut. I like to crack the nut with a nut cracker so as to avoid snapping the bolt if road debris has messed up the threads on the bolt below the nut to where it dont wanna come off easily. this would save you some labor & likely they will just need the main leaf(s) to rearch them but call em & ask.
Re: my springs are sagging [Re: mickm] #2454834
02/20/18 11:15 PM
02/20/18 11:15 PM
California
mickm Offline OP
mickm  Offline OP
California
Interesting. I had a long talk with the guy who arched the springs for me, and trying to be polite, what he said is the steel is crap. If after 2 years they have sagged not only the inch they were arched but beyond that, that is bad steel.
He also said the steel coming from Mexico currently is good stuff. India steel is bad.
I think I can attest somewhat to that, as my mopar springs that I bought years ago lasted a good 5 years or more before they started to sag. These [censored] expensive springs from Eaton didn't last 2.
He said he can put a leaf in each side that will raise it back that inch and a half, the only issue is, are they done sagging? If not, even with a good leaf in there, they will sag more.
I think I'll try and wait a bit, drive it some more, and see what it does. I'm planning on driving it to Spring Fling with some friends, but it will be bad news with 3 of us and gear in there on springs that are now 1 1/2" sagged. So I'll have to do it before April.
Re: my springs are sagging [Re: mickm] #2454837
02/20/18 11:22 PM
02/20/18 11:22 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i got some Alcan springs made for my powerwagon and they told me or it says on their website that it's normal for springs to sag a little. steel wears out, guys that abuse their springs hard might only get a few years out of them...
i imagine it applies similarly to high HP cars that are driven hard...
Re: my springs are sagging [Re: mickm] #2454933
02/21/18 03:16 AM
02/21/18 03:16 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
If you add a leaf make sure it is the second leaf, and make sure it goes all the way to or a little past the front eye bolt, and close to the rear one. The only way to stop this is to add more metal, or a thicker main. This has worked for me, rearching or adding a short leaf never has. Ride quality will suffer.
Re: my springs are sagging [Re: mickm] #2454934
02/21/18 03:21 AM
02/21/18 03:21 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I once played with springs in a 73 Duster...
This is what happens when the second leaf is too short!
Re: my springs are sagging [Re: mickm] #2454956
02/21/18 04:31 AM
02/21/18 04:31 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Mick, that spring shop fed you a line.
They effed them springs up for you when they re-arched them.
"Spring steel" is beyond my understanding of Metalurgy, but it's a special metal treatment and tampering with it either by cold bending or hot bending ruins them.
Cheapest solution is to get a couple of off-shelf leafs with more arch than what you have now and add them to your spring pack. Hope for the best that your car will sit level on both sides and you get the height you want.
Mo' Farts
Moderated by "tbagger".
Re: my springs are sagging [Re: Kern Dog] #2455011
02/21/18 11:32 AM
02/21/18 11:32 AM
St. Charles, MO
wingman Online happy
Uncreative Title
wingman  Online Happy
Uncreative Title
St. Charles, MO
Aw, you're fine! You got 2 more holes left in those shackles to use!
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
