Nylon Vs Brass rocker bushings #2453859
02/19/18 12:17 PM
02/19/18 12:17 PM
Valencia, España
NachoRT74 Offline OP
Valencia, España
pros and cons
I wish to restore a PRW rockers set where half of the bushings got sized.
Re: Nylon Vs Brass rocker bushings [Re: NachoRT74] #2453866
02/19/18 12:25 PM
02/19/18 12:25 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Nylon will not take the beating without distorting. If you go to the Quadrant website you can find all the technical data on plastics. It wouldn't be so bad if the bushings were thick but being as thin as they are ... just not a good idea. Besides, what's wrong with bronze ?!?!?
Re: Nylon Vs Brass rocker bushings [Re: NachoRT74] #2453869
02/19/18 12:28 PM
02/19/18 12:28 PM
moparx Offline
moparx  Offline
nylon, in my opinion, would almost instantly vanish due to the rapid rocker action and heat build up. you need brass or bronze alloy for this job.
beer
