Re: Drum brake master cylinder studs
[Re: crowbait]
#2453787
02/19/18 03:39 AM
02/19/18 03:39 AM
Posts: 12,589 Great Neck,LI,new york
hemi-itis
I'm changing the master now,when I get down to the garage I will try to get you a measurement.
[Re: crowbait]
#2457594
02/25/18 11:22 PM
02/25/18 11:22 PM
Posts: 1,565 tennessee
pushbutton
tennessee
Ok
original off my 66 coronet manual drum car measures 0.240.
Both new parts store ones measure 0.360-0.370.What gives? I guess I am gonna have to look around for studs with larger knurl dia. Put a little quick set JB Weld on the knurls,It should hold until you get the nuts started. I have used super glue, the thicker kind,but the JB would work better.
[Re: crowbait]
#2458384
02/27/18 02:05 PM
02/27/18 02:05 PM
hemi-itis
I found the stud holes to be 5/16,the holes in the adapter for my master upgrade are 5/16.BUT,,the adapter I bought has larger holes in them so everything will be nut & bolted.
[Re: hemi-itis]
#2458444
02/27/18 04:01 PM
02/27/18 04:01 PM
Posts: 1,842 South Bend
John Brown
South Bend
I found the stud holes to be 5/16,the holes in the adapter for my master upgrade are 5/16.BUT,,the adapter I bought has larger holes in them so everything will be nut & bolted. How about putting sleeves on the studs, or sleeves in the holes?
