Re: Dana 60 housing questions
[Re: crackedback]
#2454260
02/19/18 11:32 PM
02/19/18 11:32 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
Drain plug might be about it.
Snubbers were the same patter throughout IIRC. Only Dana 60 made for Mopar cars had pinion snubbers, all the rest of them didn't Dana Corp. made many different Dana 60 housings for cars and pickups The axle tubes , that I know of, range from 2.5 O.D. to 3.375 O.D
[Re: Cab_Burge]
#2454572
02/20/18 02:59 PM
02/20/18 02:59 PM
Posts: 4,564 Motor City
6PKRTSE
Motor City
Snubbers were the same patter throughout IIRC. Only Dana 60 made for Mopar cars had pinion snubbers, all the rest of them didn't Dana Corp. made many different Dana 60 housings for cars and pickups The axle tubes , that I know of, range from 2.5 O.D. to 3.375 O.D I have a 1 ton Dodge truck narrowed to fit in my Challenger with no pinion snubber mounting holes & it has the 3-3/8" dia. tubes.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: crackedback]
#2454843
02/20/18 11:32 PM
02/20/18 11:32 PM
Cab_Burge
He mentioned he had a "car" center...
You Sir are correct I see after rereading it
[Re: crowbait]
#2454965
02/21/18 05:24 AM
02/21/18 05:24 AM
Cab_Burge
If your going to abuse that rear end you might want to buy some thick chromemoly tubes for it. I've used Moser 8 3/4 and Dana 60 passenger car ends on several truck Dana 60 housings for my hot rods with no problems, all of them had 35 spline axle with the green bearings though I'm almost positive that they will accept the stock wheel bearings also, regardless of the axle size or axle diameter up to 35 spline Call Moser and ask them They are a little more costly than some of the other cheaper ends that Summit sells, but they are more than good enough for what I've done
