#2453437 - 02/18/18 10:10 AM 5.7 issues
onig Offline
Loc: Canada
So my plan was to do a stock bottom end on turbo. I picked up an 04 5.7 from a Durango, no MDS or VVT. I did hear the engine run before it being pulled. It did have a rattle to it but, idled and ran fine. Sat in storage for a couple of years.
Started to pull it apart and found that the passenger side exhaust manifold was cracked and the two bolts for the rear of that manifold were broken. Upon seeing this I thought that was the cause of the rattle.
Yesterday I removed the timing cover, pan and windage tray. Then I notice a bent rod. Crank counterweight just slightly hitting bottom of piston, that was probably the rattling noise that I heard. Continuing, I move the lifters out of the way and pulled out the cam. A couple of the lobes are pitted, but their matching lifters look good.
No water in the oil, or gasoline smelling. Are these just inferior parts or is their another reason for these issues?
What are your opinions?
69 Dart, The BB is now gone, Soon to be Gen 3 Hemi...
#2453463 - 02/18/18 11:15 AM Re: 5.7 issues [Re: onig]
biff426 Offline
Loc: Delaware
Flood vehicle seen it a bunch the vehicle floods they start it bend the rod it starts making noise they think its just water in the oil they change it a couple times then it goes to auction cuz they realize it hydrauliced the motor and it is bad.
#2453480 - 02/18/18 11:41 AM Re: 5.7 issues [Re: onig]
onig Offline
Loc: Canada
No floods in my area. Apparently it started while the vehicle was being driven. The oil was dirty used oil that we typically see when doing an oil change. The Durango was taken to a tech to see cost on repair. They decided not to repair.
#2453508 - 02/18/18 01:09 PM Re: 5.7 issues [Re: onig]
RTSrunner Offline
Loc: Pittsburgh,PA
The Durango is noted for having a cowl that lets water run onto the intake.On cold startup the engine will have water pooled on the intake/head area.Either leaking intake gaskets or the MLS head gaskets are relaxed (higher mileage engines) and sucks the water in on startup.Your is at least rebuildable! The Durango I bought had hydraliced a cylinder and broke a rod and the block.The big end of the rod still spun normally on the crank and the crank itself was ok.Powdered metal rods normally snap vs bend like yours.What cylinder was the bent rod on ##7 or 8 perhaps?
RT
Edited by RTSrunner (02/18/18 01:10 PM)
#2453550 - 02/18/18 02:47 PM Re: 5.7 issues [Re: onig]
sp392 Offline
Loc: Etobicoke
A big puddle can do that
#2453595 - 02/18/18 04:33 PM Re: 5.7 issues [Re: onig]
onig Offline
Loc: Canada
Cylinder Number 3.
#2453645 - 02/18/18 07:02 PM Re: 5.7 issues [Re: onig]
71yelladustr Offline
Loc: Missouri U.S.A.
I’m amazed the rod bent instead of breaking and taking out the block. Looks like a good excuse to put some better parts in it.
365” gen III hemi on E-85 727 trans Dana 60
10.35@131
#2453692 - 02/18/18 08:35 PM Re: 5.7 issues [Re: 71yelladustr]
RTSrunner Offline
Loc: Pittsburgh,PA
Exactly,powdered metal is brittle and generally snaps.
#2453744 - 02/18/18 10:30 PM Re: 5.7 issues [Re: 71yelladustr]
onig Offline
Loc: Canada
I know, I hear you.
Just wasn't ready to do it just yet.
#2453745 - 02/18/18 10:31 PM Re: 5.7 issues [Re: onig]
onig Offline
Loc: Canada
What about the pitting on the cam lobes?
#2453762 - 02/18/18 11:16 PM Re: 5.7 issues [Re: onig]
Silver70 Offline
Loc: Rust Belt, SW PA
Buy a single rod/piston and put it back together... used cams are cheap too. You could swap in 09+ pistons/rods and lower the compression for boost.
#2453974 - 02/19/18 12:58 PM Re: 5.7 issues [Re: onig]
HotRodDave Offline
Loc: Kalispell Mt.
I have a few bent ones, mostly they do shatter like glass.
The 09 later rods and pistons are slightly stronger as well as they will lower your compression, unless of course you use the better eagle heads you would find on an 09 up 5.7 you just piliged rods and pistons from, then you won't need as much boost to make the same power. If your doing all that you migt as well get a 6.1 forged crank as you will need to re-balance the crank anyhow. If the stock eagle rods won't take whatever HP you intend to make you might as well buy better pistons and rods to match a stroker crank...
And for what its worth I have not seen a 09+ 5.7 rod shatter yet like the earlier ones, only bend.
68 cuda 360 notchback SOLD
1996 Ram 2500 5.9 eddy intake EQ heads, mild cam upgrade great tow rig!
#2454039 - 02/19/18 03:08 PM Re: 5.7 issues [Re: onig]
MattW Offline
Loc: Ontario Canada
Toronto!!!!
Come on you guys have more water than you know what to do with.
Have a set of new K1 stock lenght with wiseco pistons stock bore if your interested.
Canadian funds of course.
Matt
#2454110 - 02/19/18 05:30 PM Re: 5.7 issues [Re: onig]
onig Offline
Loc: Canada
Hey Matt,
part #s on those parts?
#2456604 - 02/24/18 09:18 AM Re: 5.7 issues [Re: onig]
ericlre79 Offline
Loc: Massachusetts
If you just want to put it back together, I have the rods and pistons, crank, from a complete truck engine and tranny a 03 or 04 that we tore down also have the heads, intake, tranny, convetor, harness, oil pan, etc etc etc at my shop. Bought the motor for the block of course came with everything deal....my dragpak can never have too thick wall spare blocks!
PM me if you want to go the low dough route.
If you want to hop it up, I have dragpak rods, standard bore dragpak pistons(used of course)
Eric
25,346 Registered Members
190,219 Topics
CARBON FIBER HOOD
by A/MP
06/22/18 12:22 AM
TUNING W2 HEADS
by A/MP
06/22/18 12:15 AM
727 clutch pressure plate gap newb question
by radar
06/22/18 12:01 AM
Dakota clip- who has done and retained the EFI?
by CrAzYMoPaRGuY
06/21/18 11:26 PM
