Re: ATI dampers: difference supercharged and regular version?
[Re: DGS]
#2442783
01/29/18 11:12 AM
01/29/18 11:12 AM
Posts: 9,996 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If they have different part numbers, then i would assume each one is built to dampen best in that application. Best to call them. They might even build one to suit your motor?
[Re: DGS]
#2452891
02/17/18 01:15 AM
02/17/18 01:15 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
When you order one,request a 2 inch register,Mopar uses a 2.25 register. Also please note,when using the stock water pump housing be sure the alternator belt is NOT behind the damper!! DON'T ask why I had to cut that v belt
[Re: DGS]
#2452986
02/17/18 11:53 AM
02/17/18 11:53 AM
Posts: 22,696 Bitopia
jcc
Bitopia
As I understand it, the dynamic requirements of a damper with a belt driven supercharger are much reduced, as in the supercharger system acts as a partial effective damper, almost to the point its not needed, meaning to me, using a "supercharger" rendition on a NA motor might mean you are not effectively damping your crank/rotating assembly. Of course that does not answer your question, but should be a consideration in your research..
