Page 160 of 179 1 2 158 159 160 161 162 178 179
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2452897
02/17/18 01:26 AM
02/17/18 01:26 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Time for some more weight loss!Cast master being replaced by a Strange aluminum.Clutch pedal being removed,,,,but how do I get that huge spring off ?? Was under there with a prybar with no luck work
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2452899
02/17/18 01:30 AM
02/17/18 01:30 AM
hemi-itis Offline
hemi-itis  Offline
When it's too cold to take the gloves off sawzall
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2452961
02/17/18 09:50 AM
02/17/18 09:50 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Two ways to remove the over center spring. Pound washers, alignment shims, etc between the coils when the spring is extended. Then move the pedal the other way to shorten the pivot centers and pop it off. Or loosen the pedal assy bracket (brake/clutch) from the fire wall. This will allow the clutch pedal to move far enough to easily remove it. I'd go this route and install the auto trans stuff. Then sell the clutch stuff.
Doug
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2453038
02/17/18 01:54 PM
02/17/18 01:54 PM
hemi-itis Offline
hemi-itis  Offline
Thanks Doug!
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2453075
02/17/18 03:38 PM
02/17/18 03:38 PM
fullmetaljacket Offline
Itis, you mean one of these?
Problem is and no pun intended, there is actually only one of these as I had no intention nor the time to make a few extras thinking that most if not all people would think I went to the Cookoo's nest.
I do say though, that your clutch set up brake bar is slightly lighter compared to an automatic brake bar being that the foot pad is smaller on the stick versions of the brake bar family.
Moparjohn here probably knows this as well.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2453078
02/17/18 03:41 PM
02/17/18 03:41 PM
That 63'-65' triptych of pedals is a good hot item on the swap market.
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2453079
02/17/18 03:43 PM
02/17/18 03:43 PM
Holy cow itis, you d@rn went off the deep end with a hole in one. That door just doesn't hold water anymore. LOL.
Don't try that on the frame ala Pontiac swiss cheese doodles. LOL
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2453159
02/17/18 06:53 PM
02/17/18 06:53 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
On my '80 Aspen the factory was looking to save some weight when they were required to put side impact corrugated steel in the doors. The factory took it upon itself to punch out circles and squares of the inner door frame. A bit spaced out than the '65, but the factory did realize the savings.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2453178
02/17/18 07:57 PM
02/17/18 07:57 PM
hemi-itis Offline
hemi-itis  Offline
Before I even go looking,Lee & Doug say to remove the 2 pedal set up and install a single pedal set up.I'm more concerned with saving weight than money.What are these pedals worth,than what will a single set up cost?
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2453190
02/17/18 08:42 PM
02/17/18 08:42 PM
Correct me guys, but I've seen quite a few of the automatic set-ups at swaps and for reasonable numbers.
The stick versions are the more sought after items, especially for the early B's.
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2453199
02/17/18 09:10 PM
02/17/18 09:10 PM
Don't forget to count the shavings and dust from the cuts. It adds up. LOL.
Serious, I weigh that stuff also.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2453240
02/17/18 10:53 PM
02/17/18 10:53 PM
Martinsville, IN
cdwmotorsports Online content
cdwmotorsports  Online Content
Martinsville, IN
LOL no one doubts you do grin
eBay-cdwmotorsports
Re: Real world weight loss program and it` cost.......... [Re: cdwmotorsports] #2453309
02/18/18 01:34 AM
02/18/18 01:34 AM
Aluminum keys, no spare change in the pockets, total hair cut and shave, no underwear, fast for four days, trim the finger and toe nails and last but not least, go to the bathroom. LOL.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2453360
02/18/18 04:05 AM
02/18/18 04:05 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
You forgot the Brazilian waxing too.
Re: Real world weight loss program and it` cost.......... [Re: A/MP] #2453404
02/18/18 12:05 PM
02/18/18 12:05 PM
LOL. I wanted to go there, but it was a bit extreme. Glad you mentioned it. LOL.
This weight thing is contagious.
We gain more knowledge and lose more weight.
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2453406
02/18/18 12:10 PM
02/18/18 12:10 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
On my Volare doors I drilled the holes removed the crash bar's and removed sound deadner/undercoat with paint stripper. I saved 23 pounds per door.
Have a great day
Iowan
"obsolete is neat"
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2453412
02/18/18 12:25 PM
02/18/18 12:25 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I think I see where I went wrong, plain old steel keys and my door and ignition are keyed different. I need to leave the door key in the pit! New Best coming up! lol
68 Barracuda Formula S 340
Re: Real world weight loss program and it` cost.......... [Re: Iowan] #2453646
02/18/18 10:03 PM
02/18/18 10:03 PM
I bet that undercoating and sound deadener was just as heavy as any metal crash bar material that was cut off. Usually undercoating is not applied heavy on the interior surface if at all, but I've seen some in some cases and it's usually light, but some have been heavy. I guess it depends what kind of work day the sprayer was having and what day of the week it was.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2454282
02/19/18 11:57 PM
02/19/18 11:57 PM
Martinsville, IN
Martinsville, IN
FMJ, do you by chance remember the type of aluminum bolts you are using? I have seen 2024 but wonder if there is something better to use. I have to order mine regardless as apparently I’m the only one in my small town to request aluminum bolts and it causes some funny looks, I look at them the same way when they tell me they don’t have aluminum bolts but the do have aluminum sheet metal screws.
eBay-cdwmotorsports
Re: Real world weight loss program and it` cost.......... [Re: cdwmotorsports] #2454367
02/20/18 01:54 AM
02/20/18 01:54 AM
T-2024 is for the most part the grades of aluminum bolts that I have used over the years. You can also try getting T-6061 bolts, but they will be a little pricier and a tad hair heavier because of their different alloys in the mix.
Mcmasters usually has all grades in stock ready to ship.
