Roller pilot bearing part number
#2430588
01/07/18 04:54 PM
01/07/18 04:54 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
I'm sorry to have to ask; I'd written this info down in a folder of important info. Can't locate the darn folder. Of course I need to order one now.
What is the part number for the end of crank shaft roller bearing that replaces the bronze pilot bushing on a 4 speed car? These were the hot ticket when the crank wasn't drilled out completely or bored to the right dimension for the bushing.
Thanks in advance.
Lead, follow or get the hell out of the way
Re: Roller pilot bearing part number
[Re: Centerline]
#2430622
01/07/18 06:10 PM
01/07/18 06:10 PM
peabodyracing
Minnesota
Great! Thanks so much. I'm back on track. Thanks again.
[Re: peabodyracing]
#2430664
01/07/18 07:29 PM
01/07/18 07:29 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Not only is it the hot ticket, it's an upgrade. Bearing > bushing. Also check the depth of the hole.
[Re: Magnum]
#2430756
01/07/18 10:16 PM
01/07/18 10:16 PM
peabodyracing
Minnesota
Thanks for the additional input.
I'm clear on the input shaft length exposure and in fact am using this bearing so I can use an 833 which already had the shaft cut down. For a while there you could pick them up cheaper if the shaft was cut.
Had purchased a bearing already, but then my brother needed one so I gave him mine. He hadn't saved the box for the part number and my filing system failed me. Come to think of it he never paid me for the bearing......
[Re: Supercuda]
#2450427
02/12/18 12:21 AM
02/12/18 12:21 AM
Posts: 356 NE
moparpoolman
NE
[Re: Supercuda]
#2453047
02/17/18 02:13 PM
02/17/18 02:13 PM
Posts: 356 NE
moparpoolman
NE
just got the Timken FC69907 from rock auto and it is the same roller type as the National seen in the picture in the previous post. That was a disappointment. Is there a sealed ball bearing available??
[Re: moparpoolman]
#2454192
02/19/18 10:46 PM
02/19/18 10:46 PM
Posts: 356 NE
moparpoolman
NE
just got the Timken FC69907 from rock auto and it is the same roller type as the National seen in the picture in the previous post. That was a disappointment. Is there a sealed ball bearing available?? Supercuda, Have you bought one of these or seen one in person? Has anyone seen a sealed ball bearing pilot bearing? Did they send me the wrong one? or was I given the wrong part number? or just bad information?
[Re: peabodyracing]
#2454478
02/20/18 12:17 PM
02/20/18 12:17 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
I've never seen a ball bearing unit that will fit the crank flange. These needle bearing units came stock on Dakotas and worked very well. Just wondering why you feel the need ball bearings.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
[Re: 135sohc]
#2454921
02/21/18 02:20 AM
02/21/18 02:20 AM
Posts: 954 garnett kansas
rhad
garnett kansas
i have seen a couple of the input needle bearing that failed/worn out and they really chewed up the tip of the input shaft,mopar did have a similar type that is a brass bushing,dont know if its still available or not
my ladder of success is missing some rungs
