Re: 8 3/4 pumpkin gasket/sealer? [Re: RapidRobert] #2452687
02/16/18 06:29 PM
02/16/18 06:29 PM
Wisconsin
wkroncke17 Offline OP
Wisconsin
Originally Posted By RapidRobert
As said (by some) just me I would not use RTV or TRS in that app, too much scraping to get the RTV off if you think you might be swapping pigs soon (most wouldn't be tho) & with TRS I'd about wanna put a nut on em & drive out the studs before attempting to scrape that stuff off. with cleaned surfaces expecially at the base of the studs, that a dry gasket would suffice, maybe a premium superformance one & even lubeing the gasket if frequent changes are anticipated. You do have a fairly wide contact area there. #1 check for debris.
Thanks Robert!!
I don't plan on swapping it out anytime soon - but, you know how the best laid plans go....
If I ever go to experimenting with gear ratios, I will definitely try a good gasket and grease.
I made sure both surfaces were hermetically clean before the thin bead of TRS.
My memory reminded me to torque the nuts to 45 ft. pds---sound right?
Re: 8 3/4 pumpkin gasket/sealer? [Re: wkroncke17] #2452805
02/16/18 09:54 PM
02/16/18 09:54 PM
iirc 45 yes. & hermetically clean is even more cleaner than surgically clean right! (no oxygen present?).
Re: 8 3/4 pumpkin gasket/sealer? [Re: wkroncke17] #2452896
02/17/18 01:24 AM
02/17/18 01:24 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
If you are going to the drags 70/30 with an 8.75 then it will be apart again.
Re: 8 3/4 pumpkin gasket/sealer? [Re: ScottSmith_Harms] #2452901
02/17/18 01:40 AM
02/17/18 01:40 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Originally Posted By ScottSmith_Harms
The "Right Stuff" is a very good product and will likely not leak.....Just pray that you never have to remove it because that stuff is the "Super Glue" of sealants, it can be a grisly task to remove it!
This is true. I had to go back in and remove the whatever pin within the suregrip to use green bearings. I believe breaking the seal on the 3rd involved hydraulics.
That being said, I don't really need to get into the 3rd member on a remotely regular basis.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: 8 3/4 pumpkin gasket/sealer? [Re: wkroncke17] #2452949
02/17/18 05:33 AM
02/17/18 05:33 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Should have just removed the green bearings and left the 3rd member in there.
Re: 8 3/4 pumpkin gasket/sealer? [Re: NANKET] #2452998
02/17/18 12:15 PM
02/17/18 12:15 PM
jersey
Spaceman Spiff Offline
jersey
Originally Posted By NANKET
To the silicone/sealer users: how much time do you spend scraping that off both surfaces?
If you need to keep removing the pumpkin, you have more troubles than trying to get silicone off the housing.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: 8 3/4 pumpkin gasket/sealer? [Re: wkroncke17] #2453076
02/17/18 03:39 PM
02/17/18 03:39 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Anybody could have problems, but somebody else may want to change gear ratios.
Re: 8 3/4 pumpkin gasket/sealer? [Re: NANKET] #2453093
02/17/18 04:28 PM
02/17/18 04:28 PM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
Re: 8 3/4 pumpkin gasket/sealer? [Re: NANKET] #2453364
02/18/18 04:45 AM
02/18/18 04:45 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Wilwood brakes require them.
2020 RAM 1500
