Mid 70's Six Pack Bottom End?? Steel Or Cast Crank? #2452428
02/16/18 02:47 AM
02/16/18 02:47 AM
Emmett, Idaho
SuperStockWagon Offline OP
Emmett, Idaho
Have had this 440 sitting in the back corner of my shop for years..cast 1975. Any specific application? Cop car? Pulled out of a 2wd 77-78 truck, but don't believe it to be original.
NHRA Stock/SuperStock Class Racing..Engineered Muscle In Motion!
Re: Mid 70's Six Pack Bottom End?? Steel Or Cast Crank? [Re: SuperStockWagon] #2452433
02/16/18 03:09 AM
02/16/18 03:09 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
per the top pad work is there a partial VIN stamping on the pan rail?
6T440 E
9 5
6 = 1976 model year
T = Trenton MI engine assembly plant
440 = cu.in.
E = cast crank
9 5 = Friday 9/5/75 engine assembly date
Re: Mid 70's Six Pack Bottom End?? Steel Or Cast Crank? [Re: 6bblgt] #2452434
02/16/18 03:15 AM
02/16/18 03:15 AM
Emmett, Idaho
Emmett, Idaho
Thanks, tried to read the partial vin and was unable to..will try again tomorrow.
Re: Mid 70's Six Pack Bottom End?? Steel Or Cast Crank? [Re: SuperStockWagon] #2452435
02/16/18 03:17 AM
02/16/18 03:17 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
if it has a VIN it was a passenger car engine
Re: Mid 70's Six Pack Bottom End?? Steel Or Cast Crank? [Re: SuperStockWagon] #2452537
02/16/18 01:53 PM
02/16/18 01:53 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
wasnt E 1970 year, it is externally balanced looking at the balancer
Re: Mid 70's Six Pack Bottom End?? Steel Or Cast Crank? [Re: SuperStockWagon] #2452543
02/16/18 02:09 PM
02/16/18 02:09 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The balancer should be stamped saying cast crank only.
Re: Mid 70's Six Pack Bottom End?? Steel Or Cast Crank? [Re: cudaman1969] #2452564
02/16/18 02:36 PM
02/16/18 02:36 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
E440 is 1970
As Dan posted, 440E is cast crank
Re: Mid 70's Six Pack Bottom End?? Steel Or Cast Crank? [Re: 6bblgt] #2452586
02/16/18 03:05 PM
02/16/18 03:05 PM
Emmett, Idaho
Emmett, Idaho
Thanks Dan!
Re: Mid 70's Six Pack Bottom End?? Steel Or Cast Crank? [Re: SuperStockWagon] #2452592
02/16/18 03:20 PM
02/16/18 03:20 PM
home of the Buckeyes
Butterscotch71 Offline
Lost Title
Lost Title
So how is this a six pack bottom end?
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
Re: Mid 70's Six Pack Bottom End?? Steel Or Cast Crank? [Re: Butterscotch71] #2452615
02/16/18 04:12 PM
02/16/18 04:12 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
If it has the heavy 906/908 connecting rods, some may consider it to be a six pack bottom end.
Re: Mid 70's Six Pack Bottom End?? Steel Or Cast Crank? [Re: B5 Bee] #2452647
02/16/18 05:27 PM
02/16/18 05:27 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
the OP appears to be asking the question .....
is this a mid-'70s Six Pack Bottom End?? * probably NO heavy rods
does this have a Steel or Cast Crank? * CAST crank
* at least when originally assembled
6D162051 = C-body from Belvidere, IL
Re: Mid 70's Six Pack Bottom End?? Steel Or Cast Crank? [Re: SuperStockWagon] #2452662
02/16/18 05:47 PM
02/16/18 05:47 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
A 76 block, cast crank and we're talking about this maybe being a six pack bottom end?
Is this still Moparts or has the site been hacked?
Re: Mid 70's Six Pack Bottom End?? Steel Or Cast Crank? [Re: Pacnorthcuda] #2452689
02/16/18 06:34 PM
02/16/18 06:34 PM
Emmett, Idaho
Emmett, Idaho
Ok,excuse me..heavy rods/big balancer..had always heard of it referred to as a 6 pack rotating assembly..It is definitely heavier appearing (balancer)than the std cast crank 440 of the era that I've dealt with.
Re: Mid 70's Six Pack Bottom End?? Steel Or Cast Crank? [Re: SuperStockWagon] #2452727
02/16/18 07:25 PM
02/16/18 07:25 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Balancer is what's weird, I have a 74 or 75 motor home block still together with a steel crank and the big rods, But a thinner beveled edge balancer that doesn't have the balance ring. I have a police 77 cast crank balancer, but I don't think I looks like the one you have either, I'll look tonite to double check. Only thing for sure is its a c-body block, not what's inside.
I checked, neither one I have look like yours.
Re: Mid 70's Six Pack Bottom End?? Steel Or Cast Crank? [Re: B5 Bee] #2452892
02/17/18 01:15 AM
02/17/18 01:15 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
E440 is 1970
Actually E440 is 1969.
Re: Mid 70's Six Pack Bottom End?? Steel Or Cast Crank? [Re: 62maxwgn] #2452902
02/17/18 01:40 AM
02/17/18 01:40 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
E440 is 1970
Yes, my mistake. Can't blame it on a fat finger typo. rant
