Changing Jaz Radiator catch can fitting to -AN #2452810
02/16/18 10:00 PM
02/16/18 10:00 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Looking to get away from the hosebarb ends on my radiator and my plastic Jaz catch can and replacing it with AN fittings. The radiator part is easy, not sure how to plumb the catch can to a AN style.
Has anyone done this?
Re: Changing Jaz Radiator catch can fitting to -AN [Re: Sammy] #2452867
02/17/18 12:26 AM
02/17/18 12:26 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I use an aluminum catch can from Summit. It has NPT thread pitch tapped, and use #4 line from the radiator. I know, not what you are asking, but the aluminum catch can from Summit is pretty reasonable.
69 GTX 68 Road Runner
Re: Changing Jaz Radiator catch can fitting to -AN [Re: JERICOGTX] #2452883
02/17/18 12:51 AM
02/17/18 12:51 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
a plastic fuel cell has AN fittings.they just sandwitch in.
Re: Changing Jaz Radiator catch can fitting to -AN [Re: bonefish] #2452886
02/17/18 12:57 AM
02/17/18 12:57 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
http://www.jegs.com/i/Russell/799/670850/10002/-1 i dont know what size you want but this is what i was thinking,you could prob get it in a 4
Re: Changing Jaz Radiator catch can fitting to -AN [Re: Sammy] #2452887
02/17/18 01:01 AM
02/17/18 01:01 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
If you absolutely had to do an -AN fitting to plastic I would drill a hole to fit the -AN size you need and use a Male Flare to bulkhead adapter and add an o-ring behind it. Then lock it down with a bulkhead nut. Here are the XRP versions of what I am talking about.
But I agree that it may be easier to just get an aluminum catch can.
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
