18 spline speed gear bushings #2452525
02/16/18 01:19 PM
02/16/18 01:19 PM
NE
moparpoolman Offline OP
NE
Does anyone know where to get A 833 18 spline speed gear bushings? Has anyone changed them before, any tricks? Thanks
Re: 18 spline speed gear bushings [Re: moparpoolman] #2452837
02/16/18 11:18 PM
02/16/18 11:18 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Passon or Brewers should have those parts.
Re: 18 spline speed gear bushings [Re: moparpoolman] #2453241
02/17/18 10:54 PM
02/17/18 10:54 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have never had to change one before what's wrong with yours?
Gus beer
64 Plymouth Savoy
Dana 60
Re: 18 spline speed gear bushings [Re: fourgearsavoy] #2453263
02/17/18 11:40 PM
02/17/18 11:40 PM
NE
NE
The bushing oiling hole isn't lined up with the gear hole at all. I'm thinking if I were to press it out it might need a new one..
Re: 18 spline speed gear bushings [Re: moparpoolman] #2453449
02/18/18 01:40 PM
02/18/18 01:40 PM
moparx Online content
moparx  Online Content
not knowing the part, could you possibly use a drill through the oiling hole to drill through the bushing ? just a thought.
beer
Re: 18 spline speed gear bushings [Re: moparpoolman] #2453509
02/18/18 04:12 PM
02/18/18 04:12 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
If its not worn just slot thru the brass with a dremel wheel and call it good.
Re: 18 spline speed gear bushings [Re: 4406bbl] #2453647
02/18/18 10:05 PM
02/18/18 10:05 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Those bushings are staked into the gear. Like others have said just open up the bushing through the slot.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: 18 spline speed gear bushings [Re: Dan Brewer] #2453908
02/19/18 01:41 PM
02/19/18 01:41 PM
NE
NE
Thanks for the reply Dan, the bushing does seem to be a little worn so if I was going to mess around with it I think I'd rather spend the time replacing it. Are the Bushings available? Do You sell them? Thanks
Re: 18 spline speed gear bushings [Re: moparpoolman] #2454005
02/19/18 04:50 PM
02/19/18 04:50 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
I don't have any new ones left. I probably have a damaged gear that has a good bushing if you want to do it that way.
